I installed the Linux trial version while logged on as root. (Otherwise I can’t write into the /usr/pgi installation directory). When asked for the username to set up a temporary license file, I entered my usual username. I logged back in under my usual username, changed the PATH, and tried to use pgf90. I get an error:
LICENSE MANAGER PROBLEM: Cannot find license file
The license files (or server network addresses) attempted are
listed below. Use LM_LICENSE_FILE to use a different license file,
Feature: pgf90-linux86
Filename ./license.dat
License path ./license.dat
FLEXlm error: -1,359. System Eror: 2 “No such file or directory”
etc.
I am using Fedora Core 2
I don’t understand why FLEXlm is referred to, since I thought the trial license didn’t require it. All I did was ungzip, untar, and run ./install (as root).
