My computer specification are:
Windows 10
cuda 11.2
cudnn 8.0.5
Nvidia geforce GTX 3080
tensorflow-gpu 2.4.1
tensorflow 2.4.1
I used this web(GitHub - armaanpriyadarshan/Training-a-Custom-TensorFlow-2.X-Object-Detector: Learn how to train a TensorFlow Custom Object Detector with TensorFlow-GPU) to install faster rcnn. When I trained this network, it had an error:
2021-01-24 18:12:47.713443: E tensorflow/stream_executor/cuda/cuda_dnn.cc:336] Could not create cudnn handle: CUDNN_STATUS_NOT_INITIALIZED 2021-01-24 18:12:47.715010: E tensorflow/stream_executor/cuda/cuda_dnn.cc:340] Error retrieving driver version: Unimplemented: kernel reported driver version not implemented on Windows 2021-01-24 18:12:47.718097: E tensorflow/stream_executor/cuda/cuda_dnn.cc:336] Could not create cudnn handle: CUDNN_STATUS_NOT_INITIALIZED 2021-01-24 18:12:47.719553: E tensorflow/stream_executor/cuda/cuda_dnn.cc:340] Error retrieving driver version: Unimplemented: kernel reported driver version not implemented on Windows Traceback (most recent call last): File “model_main_tf2.py”, line 113, in tf.compat.v1.app.run() File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\platform\app.py”, line 40, in run _run(main=main, argv=argv, flags_parser=_parse_flags_tolerate_undef) File “C:\Anaconda\envs\tensorflow\lib\site-packages\absl\app.py”, line 300, in run _run_main(main, args) File “C:\Anaconda\envs\tensorflow\lib\site-packages\absl\app.py”, line 251, in _run_main sys.exit(main(argv)) File “model_main_tf2.py”, line 104, in main model_lib_v2.train_loop( File “C:\Anaconda\envs\tensorflow\lib\site-packages\object_detection\model_lib_v2.py”, line 561, in train_loop load_fine_tune_checkpoint(detection_model, File “C:\Anaconda\envs\tensorflow\lib\site-packages\object_detection\model_lib_v2.py”, line 361, in load_fine_tune_checkpoint strategy.run( File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\distribute\distribute_lib.py”, line 1259, in run return self._extended.call_for_each_replica(fn, args=args, kwargs=kwargs) File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\distribute\distribute_lib.py”, line 2730, in call_for_each_replica return self._call_for_each_replica(fn, args, kwargs) File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\distribute\mirrored_strategy.py”, line 628, in _call_for_each_replica return mirrored_run.call_for_each_replica( File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\distribute\mirrored_run.py”, line 75, in call_for_each_replica return wrapped(args, kwargs) File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\eager\def_function.py”, line 828, in call result = self._call(*args, **kwds) File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\eager\def_function.py”, line 888, in _call return self._stateless_fn(*args, **kwds) File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\eager\function.py”, line 2942, in call return graph_function._call_flat( File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\eager\function.py”, line 1918, in _call_flat return self._build_call_outputs(self._inference_function.call( File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\eager\function.py”, line 555, in call outputs = execute.execute( File “C:\Anaconda\envs\tensorflow\lib\site-packages\tensorflow\python\eager\execute.py”, line 59, in quick_execute tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name, tensorflow.python.framework.errors_impl.UnknownError: 2 root error(s) found. (0) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above. [[node model/conv1_conv/Conv2D (defined at \site-packages\object_detection\meta_architectures\faster_rcnn_meta_arch.py:1346) ]] [[Loss/RPNLoss/BalancedPositiveNegativeSampler/Cast_8/_192]] (1) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above. [[node model/conv1_conv/Conv2D (defined at \site-packages\object_detection\meta_architectures\faster_rcnn_meta_arch.py:1346) ]] 0 successful operations. 0 derived errors ignored. [Op:__inference__dummy_computation_fn_16411]
Errors may have originated from an input operation. Input Source operations connected to node model/conv1_conv/Conv2D: model/lambda/Pad (defined at \site-packages\object_detection\models\keras_models\resnet_v1.py:49)
Function call stack: _dummy_computation_fn → _dummy_computation_fn
How to solve this problem?
