Tensorboard was not worked when using the "19.12-tf2-py3"
Hi NV Team,
I have met the issue which the Tensorboard was not worked(i.e. could not access the tensorboard) when used the latest the docker images. (Tag name is “19.12-tf2-py3”.)
Here is the command which I used.
sudo docker run -it -p 8889:8888 -p 6006:6006 nvcr.io/nvidia/tensorflow:19.12-tf2-py3
##tensorboard --logdir /logs
Best regards.
Kaka
Hi
Would anyone give us the comments for my question?
Best regards.
Kaka
This question was also asked in the TensorFlow container forum. In case anyone else runs into the issue, the answer was to pass the --bind_all flag when starting Tensorboard.
