System information
- OS Platform and Distribution (e.g., Linux Ubuntu 16.04): windows 10
- Mobile device (e.g. iPhone 8, Pixel 2, Samsung Galaxy) if the issue happens on mobile device: Amd 3900x+ nvidia rtx 3090
- TensorFlow installed from (source or binary): source
- TensorFlow version:r2.3 v2.3 v2.3.1 v2.4
- Python version:3.8.6
- Installed using virtualenv? pip? conda?: pip
- Bazel version (if compiling from source): 3.5.1
- GCC/Compiler version (if compiling from source):
- CUDA/cuDNN version:CUDA11.1+cudnn8.0.4
- GPU model and memory:nvidia rtx 3090 24GB
Describe the problem
v2.3.1 error below
ERROR: F:/tensorflow-2.3.1/tensorflow/core/kernels/BUILD:3180:18: C++ compilation of rule ‘//tensorflow/core/kernels:image_ops_gpu’ failed (Exit 2): python.exe failed: error executing command
cd C:/users/itx/_bazel_itx/aorpfopj/execroot/org_tensorflow
SET CUDA_TOOLKIT_PATH=C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.1
SET INCLUDE=C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\ATLMFC\include;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\include;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\include\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\ucrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\shared;C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\winrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\cppwinrt
SET LIB=C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\ATLMFC\lib\x64;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\lib\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\lib\um\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.18362.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.18362.0\um\x64
SET PATH=C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\bin\HostX64\x64;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\VC\VCPackages;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\CommonExtensions\Microsoft\TestWindow;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\CommonExtensions\Microsoft\TeamFoundation\Team Explorer;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Current\bin\Roslyn;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools\x64;C:\Program Files (x86)\Windows Kits\10\bin\10.0.18362.0\x64;C:\Program Files (x86)\Windows Kits\10\bin\x64;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Current\Bin;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\Tools;;C:\WINDOWS\system32;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\CommonExtensions\Microsoft\CMake\CMake\bin;C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\CommonExtensions\Microsoft\CMake\Ninja
v2.4 error below
ERROR: C:/users/itx/_bazel_itx/vne2u2k5/external/nsync/BUILD:467:11: C++ compilation of rule ‘@nsync//:nsync_cpp’ failed (Exit 2): python.exe failed: error executing command
cd C:/users/itx/_bazel_itx/vne2u2k5/execroot/org_tensorflow
Provide the exact sequence of commands / steps that you executed before running into the problem
Any other info / logs
Include any logs or source code that would be helpful to diagnose the problem. If including tracebacks, please include the full traceback. Large logs and files should be attached.
