When I run my tensorflow keras model it will sometimes stop after an epoch and throw the following error:
tensorflow/stream_executor/dnn.cc:613] CUDNN_STATUS_EXECUTION_FAILED
in tensorflow/stream_executor/cuda/cuda_dnn.cc(1867): ‘cudnnRNNForwardTraining( cudnn.handle(), rnn_desc.handle(), model_dims.max_seq_length, input_desc.handles(), input_data.opaque(), input_h_desc.handle(), input_h_data.opaque(), input_c_desc.handle(), input_c_data.opaque(), rnn_desc.params_handle(), params.opaque(), output_desc.handles(), output_data->opaque(), output_h_desc.handle(), output_h_data->opaque(), output_c_desc.handle(), output_c_data->opaque(), workspace.opaque(), workspace.size(), reserve_space.opaque(), reserve_space.size())’
2020-06-27 17:19:45.741256: F tensorflow/stream_executor/cuda/cuda_dnn.cc:189] Check failed: status == CUDNN_STATUS_SUCCESS (7 vs. 0)Failed to set cuDNN stream.
Im using the GPU version of tensorflow and it has worked without problems up until about 3 days ago when it began giving me this error. I also have the following callbacks in my model so that it saves checkpoints and epochs locally.
my_callbacks = [tf.keras.callbacks.EarlyStopping(patience=15, restore_best_weights=True, monitor=“val_accuracy”, mode=“auto”),
tf.keras.callbacks.ModelCheckpoint(filepath=“D:\AutoKerasProject\TimeseriesCallbackModel\TimeseriesCallbackModel”, save_weights_only=True, monitor=‘val_accuracy’, mode=‘auto’, save_best_only=True)]
