HI
Can i run faster rcnn model generated from tensorflow using tensor RT on tx2 . Please share the procedure for this
The included tensorrt/samples/sampleFasterRCNN/
is TF based. The general procedure is similar. If you are encountering specific issues, please let us know.
regards,
NVIDIA Enterprise Support
Hi when i went to the location of the mentioned place the files i found were in c++ and caffe version . can you pls let me know how to build the tensorflow version
From a standard Linux TensorRT tar installation, you can find the samples (including samplefasterRCNN) at \TensorRT-5.xxx\targets\x86_64-linux-gnu\samples
If you are using NVIDIA Graphics Cloud (NGC) TensorRT container, then you’ll find the sample at: /workspace/tensorrt/samples/sampleFasterRCNN
Hi ,
This is only available in Tensor rt 5 version ? my end application is using Faster RCNN + Inception v2 model built from tensorflow , would i be able to easily deploy it on the tx2 board
the faster rcnn example is availabe for trt 4.x as well.
HI ,
Apologies for asking again but i am not able to find the tf based version of fastercnn+ inception v2 in the mentioned location , can you pls elaborate the version and location where i can find it
are you saying you can’t find the fasterrcnn sample described here? https://docs.nvidia.com/deeplearning/sdk/tensorrt-archived/tensorrt_210/tensorrt-user-guide/index.html#fasterrcnn_sample
Hi ,
I am able to find the faster rcnn files in the in the mentioned path which are all caffe version, but i am not able to find anything on the tensorflow version which i can take it and run my model which was trained with both faster rcnn + inceptionv2
