in jetson-inference, there is sample for segnet, but it supports only caffemode.
do we have some sample for segnet which support tensorflow.
We only have a caffe-based segnet model and sample.
If you already have a TensorFlow model, it’s recommended to update sample to support uff model.
Here is tutorial of uff model for your reference:
[url]https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#import_model_c[/url]
Hi AastaLLL,
Thanks for your reply.
I have flow the tutorial to convert my tensorflow model to uff model,
and try to load and parse the uff model, it is not very convenient.
Sorry that we need an intermediate model format for better maintenance.
You can always report here if meeting any issue or error.
Hi AastaLLL,
I have try to load the uff mode, and encounter this problem:
ERROR: Parameter check failed at: …/builder/Network.cpp::addInput::406, condition: isValidDims(dims)
ERROR: UFFParser: Failed to parseInput for node Placeholder
ERROR: UFFParser: Parser error: Placeholder: Failed to parse node - Invalid Tensor found at node Placeholder
ERROR: sample_uff_mnist: Fail to parse
ERROR: sample_uff_mnist: Model load failed
I want to find the source file: Network.cpp, but i can’t find it in tensorRT folder.
waiting for your help.
Thanks very much.
Hi AastaLLL,
I have resolved this error. The rootcause is that the dims in my model is not match with the parameters in the code.
The last problem:
It costs about 5min in this function:
ICudaEngine* engine = builder->buildCudaEngine(*network);
it is too long, if only happens at the first time, that is ok, but it happens every time.
How can i resolve this problem.
Thanks very much.
Good to know this.
Thanks for your update. : )
Hi, I met the same problem. Have you solved it? #ERROR: Parameter check failed at: …/builder/Network.cpp::addInput::406, condition: isValidDims(dims)
