tensorflow install step 4 problems
hi
i already did the
git check out r1.9
how to setup the following steps…
diff --git a/tensorflow/lite/kernels/internal/BUILD b/tensorflow/lite/kernels/internal/BUILD
index 4be3226..960754a 100644
--- a/tensorflow/lite/kernels/internal/BUILD
+++ b/tensorflow/lite/kernels/internal/BUILD
@@ -22,7 +22,6 @@ HARD_FP_FLAGS_IF_APPLICABLE = select({
 NEON_FLAGS_IF_APPLICABLE = select({
     ":arm": [
         "-O3",
-        "-mfpu=neon",
     ":armeabi-v7a": [
         "-O3",
diff --git a/third_party/aws/BUILD.bazel b/third_party/aws/BUILD.bazel
index 5426f79..e08f8fc 100644
--- a/third_party/aws/BUILD.bazel
+++ b/third_party/aws/BUILD.bazel
@@ -24,7 +24,7 @@ cc_library(
         "@org_tensorflow//tensorflow:raspberry_pi_armeabi": glob([
             "aws-cpp-sdk-core/source/platform/linux-shared/*.cpp",
-        "//conditions:default": [],
+        "//conditions:default": glob(["aws-cpp-sdk-core/source/platform/linux-shared/*.cpp",]),
     }) + glob([
         "aws-cpp-sdk-core/include/**/*.h",
         "aws-cpp-sdk-core/source/*.cpp",
diff --git a/third_party/gpus/crosstool/BUILD.tpl b/third_party/gpus/crosstool/BUILD.tpl
index db76306..184cd35 100644
--- a/third_party/gpus/crosstool/BUILD.tpl
+++ b/third_party/gpus/crosstool/BUILD.tpl
@@ -24,6 +24,7 @@ cc_toolchain_suite(
         "x64_windows|msvc-cl": ":cc-compiler-windows",
         "x64_windows": ":cc-compiler-windows",
         "arm": ":cc-compiler-local",
+        "aarch64": ":cc-compiler-local",
         "k8": ":cc-compiler-local",
         "piii": ":cc-compiler-local",
         "ppc": ":cc-compiler-local",
thanks
diff [file]: indicates the file you need to edit.
- [line]: remove the line
+ [line]: add the line
For example,
     ":arm": [
         "-O3",
-        "-mfpu=neon",
     ":armeabi-v7a": [
         "-O3",
Modify the file tensorflow/lite/kernels/internal/BUILD.
Remove this line:
-        "-mfpu=neon",
