Upon running
uff_model = uff.from_tensorflow_frozen_model("frozen_model.pb", ["output"])
I get the following error:
Warning: keep_dims is not supported, ignoring...
File "<stdin>", line 1, in <module>
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 103, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, **kwargs)
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 77, in from_tensorflow
uff_metagraph_proto = uff_metagraph.to_uff()
File "/usr/lib/python3.5/dist-packages/uff/model/meta_graph.py", line 39, in to_uff
graphs=[graph.to_uff(debug) for graph in self.graphs],
File "/usr/lib/python3.5/dist-packages/uff/model/meta_graph.py", line 39, in <listcomp>
File "/usr/lib/python3.5/dist-packages/uff/model/graph.py", line 26, in to_uff
graph = uff_pb.Graph(id=self.name, nodes=self._check_graph_and_get_nodes())
File "/usr/lib/python3.5/dist-packages/uff/model/graph.py", line 46, in _check_graph_and_get_nodes
raise extend_with_original_traceback(e, node._trace)
File "/usr/lib/python3.5/dist-packages/uff/model/graph.py", line 44, in _check_graph_and_get_nodes
nodes.append(self._check_and_get_node(node))
File "/usr/lib/python3.5/dist-packages/uff/model/graph.py", line 33, in _check_and_get_node
node = node.to_uff()
File "/usr/lib/python3.5/dist-packages/uff/model/node.py", line 41, in to_uff
fields=self._convert_fields(self.fields, debug),
File "/usr/lib/python3.5/dist-packages/uff/model/node.py", line 30, in _convert_fields
ret_fields[k] = create_data(v)
File "/usr/lib/python3.5/dist-packages/uff/model/data.py", line 104, in create_data
return uff_pb.Data(dtype=_create_dtype(elt))
File "/usr/lib/python3.5/dist-packages/uff/model/data.py", line 59, in _create_dtype
raise UffException("dtype {} unknown".format(dtype))
uff.model.exceptions.UffException: dtype <class 'numpy.uint8'> unknown
Is there any fix?
Looks like your model contains some non-supported layers of TensorRT.
Please check our document for supported layer in detail:
UFF parser: [url]Developer Guide :: NVIDIA Deep Learning TensorRT Documentation
TensorRT engine: [url]Developer Guide :: NVIDIA Deep Learning TensorRT Documentation
I have managed to change the layers that weren’t supported by TensorRT. Now I am facing the following error:
Using output node generate_output/deprocess/add
Converting to UFF graph
No. nodes: 361
UFF Output written to data/tmp.uff
UFFParser: parsing generate_output/generator/encoder_9/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_8/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_7/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_6/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_5/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_4/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_3/lrelu/mul/x
UFFParser: parsing generate_output/generator/encoder_2/lrelu/mul/x
UFFParser: parsing image_tensor
UFFParser: parsing generate_output/load_images/preprocess/mul/y
UFFParser: parsing generate_output/load_images/preprocess/sub/y
UFFParser: parsing generate_output/input_images/Reshape/shape
UFFParser: parsing generator/encoder_1/conv/filter
UFFParser: parsing generate_output/generator/encoder_1/conv/Conv2D
UFFParser: parsing generate_output/generator/encoder_2/lrelu/mul_1/x
UFFParser: parsing generate_output/generator/encoder_2/lrelu/Abs
UFFParser: Parser error: generate_output/generator/encoder_2/lrelu/Abs: Unary not supported for other non-constant node
Failed to parse UFF
From what I understand, the function abs is also not supported. I am attempting to replace abs with other supported Tensorflow functions.
numpy:
mask = (x<0).astype(np.float32)
mask = 2*mask + 1 #(makes all 1s -1, and all 0s 1)
abs_vals = mask*x
Tensorflow: z is a tensor of zeros, the same shape as x
mask = tf.less(x, z)
#convert mask from boolean to integer or float
I am unsure how to proceed because I need to convert the boolean mask that tensorflow returns to an integer mask, in order to multiply it to the input, but the Cast operation is also not supported by TensorRT. Any help with this will be very much appreciated.
The operations that are supported by TenosrRT arent supported by the UFF parser. How is anything going to work. I am currently facing an error because of subtracting 2 tensors. How can I replace that with anything?
Unsupported operation _Neg
We have released TensorRT 4 for host few weeks ago.
It’s recommended to give it a try first.
https://developer.nvidia.com/nvidia-tensorrt-download
You can find the detail supported layers here:
But please remember this package is not available for TX2 yet.
