Hi Folks;
Just updated my Nano with JP 452. Attempting to install TensorFlow following instructions on NVidia site. Getting the following errors…
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/urllib3/response.py”, line 438, in _error_catcher
yield
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/urllib3/response.py”, line 519, in read
data = self._fp.read(amt) if not fp_closed else b""
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/cachecontrol/filewrapper.py”, line 62, in read
data = self.__fp.read(amt)
File “/usr/lib/python3.6/http/client.py”, line 463, in read
n = self.readinto(b)
File “/usr/lib/python3.6/http/client.py”, line 507, in readinto
n = self.fp.readinto(b)
File “/usr/lib/python3.6/socket.py”, line 586, in readinto
return self._sock.recv_into(b)
File “/usr/lib/python3.6/ssl.py”, line 1012, in recv_into
return self.read(nbytes, buffer)
File “/usr/lib/python3.6/ssl.py”, line 874, in read
return self._sslobj.read(len, buffer)
File “/usr/lib/python3.6/ssl.py”, line 631, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/base_command.py”, line 180, in _main
status = self.run(options, args)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/req_command.py”, line 205, in wrapper
return func(self, options, args)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/commands/install.py”, line 319, in run
reqs, check_supported_wheels=not options.target_dir
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/resolver.py”, line 128, in resolve
requirements, max_rounds=try_to_avoid_resolution_too_deep
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/resolvelib/resolvers.py”, line 473, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/resolvelib/resolvers.py”, line 341, in resolve
name, crit = self._merge_into_criterion(r, parent=None)
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/resolvelib/resolvers.py”, line 172, in _merge_into_criterion
if not criterion.candidates:
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/resolvelib/structs.py”, line 139, in bool
return bool(self._sequence)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/found_candidates.py”, line 143, in bool
return any(self)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/found_candidates.py”, line 129, in
return (c for c in iterator if id(c) not in self._incompatible_ids)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/found_candidates.py”, line 33, in _iter_built
candidate = func()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/factory.py”, line 205, in _make_candidate_from_link
version=version,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 312, in init
version=version,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 151, in init
self.dist = self._prepare()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 234, in _prepare
dist = self._prepare_distribution()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 318, in _prepare_distribution
self._ireq, parallel_builds=True
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 508, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 552, in _prepare_linked_requirement
self.download_dir, hashes
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 243, in unpack_url
hashes=hashes,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 102, in get_http_url
from_path, content_type = download(link, temp_dir.path)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/network/download.py”, line 157, in call
for chunk in chunks:
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/progress_bars.py”, line 152, in iter
for x in it:
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/network/utils.py”, line 86, in response_chunks
decode_content=False,
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/urllib3/response.py”, line 576, in stream
data = self.read(amt=amt, decode_content=decode_content)
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/urllib3/response.py”, line 541, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File “/usr/lib/python3.6/contextlib.py”, line 99, in exit
self.gen.throw(type, value, traceback)
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/urllib3/response.py”, line 443, in _error_catcher
raise ReadTimeoutError(self._pool, None, “Read timed out.”)
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host=‘developer.download.nvidia.com’, port=443): Read timed out.
Anyone know why this is hapening on a freshly instatlled system?
Rick
