I was able to build and run C++ API r1.14 tensorflow version.
In Configure.py configuration (before build) I specified GPU 7.0.
I use RTX 2080 GeForce card, and expect to get a high Frame rate using a video from camera of my laptop.
When I use my PC internal NVIDIA GPU QUADRO P1000, the frame rate is 12 FPS.
However, the frame rate using RTX 2080 is about 6 FPS. Why is it so low ? How to speed it up ?
I disabled my PC internal NVIDIA GPU (P1000) , and verified that just RTX 2080 is running.
I also tried to speed up the GPU using the following code, but it doesn’t help:
tensorflow::SessionOptions session_options;
//session_options.config.mutable_gpu_options()->set_allow_growth(true);
tensorflow::ConfigProto* config = &session_options.config;
tensorflow::GPUOptions* gpu_options = config->mutable_gpu_options();
session_options.config.mutable_gpu_options()->set_force_gpu_compatible(true);
session_options.config.mutable_gpu_options()->allow_growth();
session_options.config.mutable_gpu_options()->set_per_process_gpu_memory_fraction(1.0);
tensorflow::NewSession(session_options);
