I have been trying to integrate tensorflow with Nvidia digits and I already have caffe working successfully with Nvdia Digits. However I have successfully installed tensorflow into my system
Target //tensorflow/tools/pip_package:build_pip_package up-to-date:
bazel-bin/tensorflow/tools/pip_package/build_pip_package
INFO: Elapsed time: 3517.322s, Critical Path: 250.75s
INFO: 9346 processes: 9346 local.
INFO: Build completed successfully, 9500 total actions
I ran these 2 commands to verify the installation
<b>python -c "import tensorflow as tf; print(tf.version)"</b>
/home/path/.local/lib/python3.5/site-packages/tensorflow/python/framework/dtypes.py:523: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint8 = np.dtype([("qint8", np.int8, 1)])
/home/path/.local/lib/python3.5/site-packages/tensorflow/python/framework/dtypes.py:524: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/home/path/.local/lib/python3.5/site-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint16 = np.dtype([("qint16", np.int16, 1)])
/home/path/.local/lib/python3.5/site-packages/tensorflow/python/framework/dtypes.py:526: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/home/path/.local/lib/python3.5/site-packages/tensorflow/python/framework/dtypes.py:527: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint32 = np.dtype([("qint32", np.int32, 1)])
/home/path/.local/lib/python3.5/site-packages/tensorflow/python/framework/dtypes.py:532: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
np_resource = np.dtype([("resource", np.ubyte, 1)])
1.12.0
<b>python -c "import tensorflow as tf; print(tf.contrib.eager.num_gpus())"</b>
2019-12-25 18:15:33.357674: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-12-25 18:15:33.416894: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:964] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-25 18:15:33.417115: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Found device 0 with properties:
name: GeForce GTX 1050 major: 6 minor: 1 memoryClockRate(GHz): 1.455
pciBusID: 0000:01:00.0
totalMemory: 1.95GiB freeMemory: 1.65GiB
2019-12-25 18:15:33.417129: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1511] Adding visible gpu devices: 0
2019-12-25 18:15:33.634565: I tensorflow/core/common_runtime/gpu/gpu_device.cc:982] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-12-25 18:15:33.634593: I tensorflow/core/common_runtime/gpu/gpu_device.cc:988] 0
2019-12-25 18:15:33.634599: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 0: N
2019-12-25 18:15:33.634702: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 1397 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1050, pci bus id: 0000:01:00.0, compute capability: 6.1)
1
But still my Nvidia digits server says Tensorflow support disabled. Can anyone please guide me through this? Does the python version I used to build Nvidia Digits and Caffe has to be same as python
version I used to build Tensorflow? Cause for bulding Nvidia Digits and Caffe I used python version 2.7 while I used python 3.5 for building Tensorflow. Will that make any difference? I am not sure is this beacuse of different python versions. Thanks
