1. convert_to_uff tool can’t launch without specified full convert_to_uff.py file.
2. event I run
python /usr/local/lib/python2.7/dist-packages/uff/bin/convert_to_uff.py tensorflow -o ./hello_world.uff -t --input-file ./hello_world_frozen.pb -O stream0/classifier/logits/BiasAdd -I input_images_ph
I got
Loading ./hello_world_frozen.pb
Using output node stream0/classifier/logits/BiasAdd
File "/usr/local/lib/python2.7/dist-packages/uff/bin/convert_to_uff.py", line 109, in <module>
main()
File "/usr/local/lib/python2.7/dist-packages/uff/bin/convert_to_uff.py", line 104, in main
output_filename=args.output
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 103, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 55, in from_tensorflow
name, new_name, dtype, shape = name_data.split(',', 3)
ValueError: need more than 1 value to unpack
3. solution: I just removed the -I option, then it goes further.
