I’m trying to implement my dnn model inference with tensorrt-3. I want to convert input data from HWC format to CHW. But when I use the transpose operation of IShuffleLayer, it seems that I can’t permute the channel dimension with the spatial dimension. Here’s my code for testing permutation:
void test(float* in, float* out)
Logger gLogger;
nvinfer1::IBuilder* builder = createInferBuilder(gLogger);
nvinfer1::INetworkDefinition* network = builder->createNetwork();
// Create input
auto data = network->addInput("data", nvinfer1::DataType::kFLOAT, nvinfer1::DimsCHW{4, 4, 3});
assert(data != nullptr);
// Permute
auto ps = network->addShuffle(*data);
assert(ps != nullptr);
std::cout << "ps transpose" << std::endl;
ps->setFirstTranspose(nvinfer1::Permutation{1, 2, 0});
// Set output layer
ps->getOutput(0)->setName("out");
network->markOutput(*ps->getOutput(0));
// Build the engine
builder->setMaxBatchSize(1);
builder->setMaxWorkspaceSize(1 << 20);
nvinfer1::ICudaEngine* engine = builder->buildCudaEngine(*network);
network->destroy();
assert(engine != nullptr);
nvinfer1::IExecutionContext* context = engine->createExecutionContext();
assert(context != nullptr);
assert(engine->getNbBindings() == 2);
int inputIndex = engine->getBindingIndex("data");
int outputIndex = engine->getBindingIndex("out");
void* buffers[2];
CHECK(cudaMalloc(&buffers[inputIndex], 64 * sizeof(float)));
CHECK(cudaMalloc(&buffers[outputIndex], 64 * sizeof(float)));
cudaStream_t stream;
CHECK(cudaStreamCreate(&stream));
CHECK(cudaMemcpyAsync(buffers[inputIndex], in, 64 * sizeof(float), cudaMemcpyHostToDevice, stream));
context->enqueue(1, buffers, stream, nullptr);
CHECK(cudaMemcpyAsync(out, buffers[outputIndex], 64 * sizeof(float), cudaMemcpyDeviceToHost, stream));
cudaStreamSynchronize(stream);
// release the stream and the buffers
cudaStreamDestroy(stream);
CHECK(cudaFree(buffers[inputIndex]));
CHECK(cudaFree(buffers[outputIndex]));
engine->destroy();
builder->destroy();
input data is a float buffer, and when I execute this code I get following errors:
Enhance: helpers.cpp:39: nvinfer1::DimsCHW nvinfer1::getCHW(const nvinfer1::Dims&): Assertion `isIndexedCHW(d)’ failed.
The program has unexpectedly finished.
And it seems ok when I just set the permutation as [0, 2, 1] that will keep the channel dimension and just transpose in spatial dimensions.
Any suggestion?
Thank you very much in advance!
