I am trying to use TensorRT 4.0.0.3 to perform inference on a Resnet50 model that I have trained in Keras (with Tensorflow backend).
I am able to freeze the tensorflow graph and convert it to uff format. But when I try to create a TensorRT Engine using the uff graph, I receive the following error:
[TensorRT] ERROR: Parameter check failed at: ../builder/Network.cpp::addInput::377, condition: isValidDims(dims)
[1] 14165 segmentation fault (core dumped) python tmp.py
Here is the program I am trying to run:
import tensorflow as tf
from keras import backend as K
from keras.applications.resnet50 import ResNet50
import uff
import tensorrt as trt
from tensorrt.parsers import uffparser
with K.get_session() as sess:
image_batch_t = tf.placeholder(tf.float32, shape=(None, 224, 224, 3))
model = ResNet50(input_tensor=image_batch_t,
weights='imagenet',
include_top=False)
K.set_learning_phase(0)
conf_t = model(image_batch_t)
output_names = [conf_t.name[:-2]]
graphdef = sess.graph.as_graph_def()
frozen_graph = tf.graph_util.convert_variables_to_constants(sess, graphdef, output_names)
frozen_graph = tf.graph_util.remove_training_nodes(frozen_graph)
uff_model = uff.from_tensorflow(frozen_graph, output_names)
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.ERROR)
parser = uffparser.create_uff_parser()
input_shape = (3, 224, 224)
parser.register_input("placeholder", input_shape, 1)
parser.register_output(output_names[0])
engine = trt.utils.uff_to_trt_engine(G_LOGGER,
uff_model,
parser,
1,
1 << 30)
parser.destroy()
print('success')
The whole output of this program is:
2018-04-16 15:21:41.178976: I tensorflow/core/platform/cpu_feature_guard.cc:140] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2018-04-16 15:21:43.057830: W tensorflow/stream_executor/cuda/cuda_driver.cc:527] A non-primary context 0x551ea70 for device 0 exists before initializing the StreamExecutor. The primary context is now 0x55283c0. We haven't verified StreamExecutor works with that.
2018-04-16 15:21:43.392835: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1344] Found device 0 with properties:
name: GeForce GTX 1070 major: 6 minor: 1 memoryClockRate(GHz): 1.683
pciBusID: 0000:82:00.0
totalMemory: 7.92GiB freeMemory: 7.74GiB
2018-04-16 15:21:43.392877: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1423] Adding visible gpu devices: 0
2018-04-16 15:21:44.983678: I tensorflow/core/common_runtime/gpu/gpu_device.cc:911] Device interconnect StreamExecutor with strength 1 edge matrix:
2018-04-16 15:21:44.983744: I tensorflow/core/common_runtime/gpu/gpu_device.cc:917] 0
2018-04-16 15:21:44.983753: I tensorflow/core/common_runtime/gpu/gpu_device.cc:930] 0: N
2018-04-16 15:21:44.984160: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1041] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 7459 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1070, pci bus id: 0000:82:00.0, compute capability: 6.1)
Converted 318 variables to const ops.
Using output node resnet50/avg_pool/AvgPool
Converting to UFF graph
No. nodes: 917
Library information:
- Cuda 9.0
- Cudnn 7.0.5
- TensorRT 4.0.0.3
- Tensorflow 1.7.0
- Keras 2.1.4
Additional comments:
- I have read that TensorRT will remove tensorflow reshape ops from the graph_def, which can lead to dimension incompatibility issues. I have checked the Keras Resnet50 graph used above, and there are no reshape ops.
- Thanks for any help.
