Hello everyone, I have installed the dependancies following the README.md. While the errors occured,
Layer of type yolo not supported, skipping ONNX node generation.
graph YOLOv3-608 (
%000_net[FLOAT, 64x3x608x608]
) initializers (
%001_convolutional_bn_scale[FLOAT, 32]
%106_convolutional = Conv[auto_pad = u'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%105_convolutional_lrelu, %106_convolutional_conv_weights, %106_convolutional_conv_bias)
return %082_convolutional, %094_convolutional, %106_convolutional
File "yolov3_to_onnx.py", line 760, in <module>
main()
File "yolov3_to_onnx.py", line 753, in main
onnx.checker.check_model(yolov3_model_def)
File "/search/speech/tk/.local/lib/python2.7/site-packages/onnx/checker.py", line 86, in check_model
C.check_model(model.SerializeToString())
onnx.onnx_cpp2py_export.checker.ValidationError: Node (086_upsample) has input size 1 not in range [min=2, max=2].
==> Context: Bad node spec: input: "085_convolutional_lrelu" output: "086_upsample" name: "086_upsample" op_type: "Upsample" attribute { name: "mode" s: "nearest" type: STRING } attribute { name: "scales" floats: 1 floats: 1 floats: 2 floats: 2 type: FLOATS }
Could you give me some advices here? Thanks!
