The following packages have unmet dependencies.
tensorrt : Depends: libnvinfer5 (= 5.1.2-1+cuda10.0) but it is not going to be installed
Depends: libnvinfer-dev (= 5.1.2-1+cuda10.0) but it is not going to be installed
Depends: libnvinfer-samples (= 5.1.2-1+cuda10.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I don’t think it’s because of the broken packages as I’ve downloaded the debian file from nvidia website and tried again.
Also which version of CUDA & cudnn should I use for TRT 5.1.2 ?
Also which version of CUDA & cudnn should I use for TRT 5.1.2 ?[/quote
Im afraid that tensorrt can only be installed through Jetpack which means you cant install yourself with .deb file.Because these files are compiled for x86-64 architecture not arm64 which TX2 used.
