I find that refitter only read weights in refit_cuda_engine call, if we don’t keep arrays alive before call refit_cuda_engine, the refitter will silently read invalid memory.
see a function below (it refit a engine from a pytorch module):
def refit_engine(self, net):
with trt.Refitter(self.engine, self.logger) as refitter:
state_dict = net.state_dict()
variables = []
# Why use a variable list?
# we know that in c++ functions, a python array may be deleted
# after ref count of a var decrease to zero.
# TensorRT 5.1.5.0 refitter ONLY EXECUTED in refit_cuda_engine,
# so we must keep variable alive before refit_cuda_engine call.
for k, v in self.refit_weight_dict.items():
if v["type"] == "Linear":
weight = state_dict[v["weight"]].t().detach().cpu().numpy()
refitter.set_weights(k, trt.WeightsRole.KERNEL,
weight)
variables.append(weight)
if "bias" in v:
bias = state_dict[v["bias"]].detach().cpu().numpy()
refitter.set_weights(k, trt.WeightsRole.BIAS,
bias)
variables.append(bias)
elif v["type"] == "Convolution":
weight = state_dict[v["weight"]].detach().float().cpu().numpy()
weight)
if "bias" in v:
bias)
elif v["type"] == "BatchNorm":
running_var = state_dict[v["running_var"]]
running_mean = state_dict[v["running_mean"]]
eps = v["eps"]
running_mean = running_mean.detach().cpu().numpy()
running_var = running_var.detach().cpu().numpy()
weight = weight.detach().cpu().numpy()
bias = bias.detach().cpu().numpy()
shift = (-running_mean / np.sqrt(running_var + eps)) * weight + bias
scale = weight / np.sqrt(running_var + eps)
refitter.set_weights(k, trt.WeightsRole.SCALE,
scale)
refitter.set_weights(k, trt.WeightsRole.SHIFT,
shift)
variables.append(scale)
variables.append(shift)
else:
raise NotImplementedError
# Get description of missing weights. This should return empty
# lists in this case.
[missingLayers, weightRoles] = refitter.get_missing()
assert len(missingLayers) == 0, "Refitter found missing weights. Call set_weights() for all missing weights"
# Refit the engine with the new weights. This will return True if
# the refit operation succeeded.
assert refitter.refit_cuda_engine()
