Hi i have converted a model from pytorch to onnx with no error, but when i try to convert the onnx version to tensorRT i got this error
[TensorRT] ERROR: (Unnamed Layer* 3) [Parametric ReLU]: slope tensor must be unidirectional broadcastable to input tensor
In node 3 (importMaxPool): INVALID_NODE: Assertion failed: dims.nbDims >= 2
Could someone please help me to solve this?
SunilJB
November 14, 2019, 4:17am
2
Can you provide the following information so we can better help?
Provide details on the platforms you are using:
o Linux distro and version
o GPU type
o Nvidia driver version
o CUDA version
o CUDNN version
o Python version [if using python]
o Tensorflow version
o TensorRT version
o If Jetson, OS, hw versions
Also, if possible could you please share the model file along with the conversion scripts?
Thanks for your reply.
I have ubuntu 16.04 Nvidia driver 410 cuda version 10.0. Cudnn version 7.5. Pytorch version 1.1 Tensorrt 6 is on a different machine with ubuntu 18.04 cuda 10.1 cudnn 7.6.3 . I have followed the guide at this link Installation Guide :: NVIDIA Deep Learning TensorRT Documentation .
The onnx model is ok because i have checked it with Pytorch. When i’am trying to convert it in Tensorrt on the second machine i have the above error.
At this link you can download the model final2.onnx - Google Drive
SunilJB
November 19, 2019, 5:39am
4
SunilJB
November 20, 2019, 4:31am
5
Your model does not follow the ONNX spec: The PRelu node needs to have it’s slopes input to follow unidirectional broadcasting rules.
https://github.com/onnx/onnx/blob/master/docs/Operators.md#PRelu
https://github.com/onnx/onnx/blob/master/docs/Broadcasting.md#unidirectional-broadcasting
The inputs into the node are the data tensor (size [32,64,122,122]) and slopes (size [64]). Slopes is not broadcastable out of the box. You need to update slope tensors to be size [64,1,1]
thanks i will try to change the model and let you know.
If you have time can you explain me how have you debug this error? There are some tools to check if onnx model in not working. I’m using standard pytorch function to verify if the model is ok, but i haven’t receive any type of error from converting it.
SunilJB
November 21, 2019, 9:10am
7
@eric , I have met the same problem, have you solved it?
i haven’t resolved it yet. But it’s a problem with my pytorch model because with mxnet i am able to convert the model with Prelu. As soon as i find a solution i will share it.
Thanks,
Eric
i also meet onnx to trt prelu layer problem in jetpack4.3.
i have tried ./trtexec with command line as below:
./trtexec --onnx=/home/ubuntu/temp_onnx/face_partial_upload.onnx --saveEngine=/home/ubuntu/temp_onnx/face_partial_upload.trt --fp16 --shapes=input:1x3x112x112 --verbose --exportTimes=~/temp_onnx/times.json
[1x3x112x112] is exactly the model input shape, but trtexec FAILED with output:
&&&& RUNNING TensorRT.trtexec # ./trtexec --onnx=/home/ubuntu/temp_onnx/face_partial_upload.onnx --saveEngine=/home/ubuntu/temp_onnx/face_partial_upload.trt --fp16 --shapes=input:1x3x112x112 --verbose --exportTimes=~/temp_onnx/times.json
[11/20/2019-17:36:31] [I] === Model Options ===
[11/20/2019-17:36:31] [I] Format: ONNX
[11/20/2019-17:36:31] [I] Model: /home/ubuntu/temp_onnx/face_partial_upload.onnx
[11/20/2019-17:36:31] [I] Output:
[11/20/2019-17:36:31] [I] === Build Options ===
[11/20/2019-17:36:31] [I] Max batch: explicit
[11/20/2019-17:36:31] [I] Workspace: 16 MB
[11/20/2019-17:36:31] [I] minTiming: 1
[11/20/2019-17:36:31] [I] avgTiming: 8
[11/20/2019-17:36:31] [I] Precision: FP16
[11/20/2019-17:36:31] [I] Calibration:
[11/20/2019-17:36:31] [I] Safe mode: Disabled
[11/20/2019-17:36:31] [I] Save engine: /home/ubuntu/temp_onnx/face_partial_upload.trt
[11/20/2019-17:36:31] [I] Load engine:
[11/20/2019-17:36:31] [I] Inputs format: fp32:CHW
[11/20/2019-17:36:31] [I] Outputs format: fp32:CHW
[11/20/2019-17:36:31] [I] Input build shape: input=1x3x112x112+1x3x112x112+1x3x112x112
[11/20/2019-17:36:31] [I] === System Options ===
[11/20/2019-17:36:31] [I] Device: 0
[11/20/2019-17:36:31] [I] DLACore:
[11/20/2019-17:36:31] [I] Plugins:
[11/20/2019-17:36:31] [I] === Inference Options ===
[11/20/2019-17:36:31] [I] Batch: Explicit
[11/20/2019-17:36:31] [I] Iterations: 10 (200 ms warm up)
[11/20/2019-17:36:31] [I] Duration: 10s
[11/20/2019-17:36:31] [I] Sleep time: 0ms
[11/20/2019-17:36:31] [I] Streams: 1
[11/20/2019-17:36:31] [I] Spin-wait: Disabled
[11/20/2019-17:36:31] [I] Multithreading: Enabled
[11/20/2019-17:36:31] [I] CUDA Graph: Disabled
[11/20/2019-17:36:31] [I] Skip inference: Disabled
[11/20/2019-17:36:31] [I] === Reporting Options ===
[11/20/2019-17:36:31] [I] Verbose: Enabled
[11/20/2019-17:36:31] [I] Averages: 10 inferences
[11/20/2019-17:36:31] [I] Percentile: 99
[11/20/2019-17:36:31] [I] Dump output: Disabled
[11/20/2019-17:36:31] [I] Profile: Disabled
[11/20/2019-17:36:31] [I] Export timing to JSON file: ~/temp_onnx/times.json
[11/20/2019-17:36:31] [I] Export profile to JSON file:
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - GridAnchorRect_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - NMS_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - Reorg_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - Region_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - Clip_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - LReLU_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - PriorBox_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - Normalize_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - RPROI_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[11/20/2019-17:36:31] [V] [TRT] Plugin Creator registration succeeded - FlattenConcat_TRT
Input filename: /home/ubuntu/temp_onnx/face_partial_upload.onnx
ONNX IR version: 0.0.3
Opset version: 9
Producer name: pytorch
Producer version: 0.4
Domain:
Model version: 0
Doc string:
[11/20/2019-17:36:33] [V] [TRT] /home/jenkins/workspace/TensorRT/helpers/rel-6.0/L1_Nightly/build/source/parsers/onnxOpenSource/builtin_op_importers.cpp:773: Convolution input dimensions: (3, 112, 112)
[11/20/2019-17:36:33] [E] [TRT] (Unnamed Layer* 0) [Convolution]: at least 4 dimensions are required for input
[11/20/2019-17:36:33] [V] [TRT] /home/jenkins/workspace/TensorRT/helpers/rel-6.0/L1_Nightly/build/source/parsers/onnxOpenSource/builtin_op_importers.cpp:840: Using kernel: (3, 3), strides: (2, 2), padding: (1, 1), dilations: (1, 1), numOutputs: 64
[11/20/2019-17:36:33] [V] [TRT] /home/jenkins/workspace/TensorRT/helpers/rel-6.0/L1_Nightly/build/source/parsers/onnxOpenSource/builtin_op_importers.cpp:841: Convolution output dimensions: (0)
[11/20/2019-17:36:33] [V] [TRT] 8:Conv ->
While parsing node number 1 [BatchNormalization -> "9"]:
--- Begin node ---
input: "8"
input: "2"
input: "3"
input: "4"
input: "5"
output: "9"
op_type: "BatchNormalization"
attribute {
f: 1e-05
type: FLOAT
attribute {
f: 1
type: FLOAT
doc_string: "/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/functional.py(1623): batch_norm\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/batchnorm.py(76): forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(477): _slow_forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(487): __call__\n/home/bokyliu/dukto/fxp/AirFace/2d_facerecognition/20191119-1/test/airFace.py(61): forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(477): _slow_forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(487): __call__\n/home/bokyliu/dukto/fxp/AirFace/2d_facerecognition/20191119-1/test/airFace.py(145): forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(477): _slow_forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(487): __call__\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/jit/__init__.py(252): forward\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/nn/modules/module.py(489): __call__\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/jit/__init__.py(197): get_trace_graph\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/onnx/utils.py(192): _trace_and_get_graph_from_model\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/onnx/utils.py(224): _model_to_graph\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/onnx/utils.py(281): _export\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/onnx/utils.py(104): export\n/home/bokyliu/anaconda3/envs/pytorch1/lib/python3.6/site-packages/torch/onnx/__init__.py(27): export\n/home/bokyliu/dukto/fxp/AirFace/2d_facerecognition/20191119-1/test/pytorch2onnx.py(85): <module>\n"
--- End node ---
ERROR: builtin_op_importers.cpp:695 In function importBatchNormalization:
[6] Assertion failed: scale_weights.shape == weights_shape
[11/20/2019-17:36:33] [E] Failed to parse onnx file
[11/20/2019-17:36:33] [E] Parsing model failed
[11/20/2019-17:36:33] [E] Engine could not be created
&&&& FAILED TensorRT.trtexec # ./trtexec --onnx=/home/ubuntu/temp_onnx/face_partial_upload.onnx --saveEngine=/home/ubuntu/temp_onnx/face_partial_upload.trt --fp16 --shapes=input:1x3x112x112 --verbose --exportTimes=~/temp_onnx/times.json
SunilJB
December 23, 2019, 5:00am
11
As per the above logs, issue doesn’t seems to be prelu layer problem.
It seems to be due to shape mismatch in the BatchNormalization layer.
Please refer to the below link:
https://github.com/onnx/onnx/blob/master/docs/Operators.md#batchnormalization
Could you please share the model file and steps to reproduce the error so we can better help?
