Hi all, how can I provide a dynamic range for tensors that are not Int32 when optimizing a resnet50 models as
./trtexec --uff=resnet50_v1.uff --output=ArgMax --uffInput=input_tensor,3,224,224 --iterations=40 --int8 --batch=8 --device=0 --avgRuns=100
See below the tracelog:
&&&& RUNNING TensorRT.trtexec # ./trtexec --uff=resnet50_v1.uff --output=ArgMax --uffInput=input_tensor,3,224,224 --iterations=40 --int8 --batch=8 --device=0 --avgRuns=100
[08/30/2019-20:35:17] [I] === Model Options ===
[08/30/2019-20:35:17] [I] Format: UFF
[08/30/2019-20:35:17] [I] Model: resnet50_v1.uff
[08/30/2019-20:35:17] [I] Uff Inputs Layout: NCHW
[08/30/2019-20:35:17] [I] Input: input_tensor,3,224,224
[08/30/2019-20:35:17] [I] Output: ArgMax
[08/30/2019-20:35:17] [I] === Build Options ===
[08/30/2019-20:35:17] [I] Max batch: 8
[08/30/2019-20:35:17] [I] Workspace: 16 MB
[08/30/2019-20:35:17] [I] minTiming: 1
[08/30/2019-20:35:17] [I] avgTiming: 8
[08/30/2019-20:35:17] [I] Precision: INT8
[08/30/2019-20:35:17] [I] Calibration: Dynamic
[08/30/2019-20:35:17] [I] Safe mode: Disabled
[08/30/2019-20:35:17] [I] Save engine:
[08/30/2019-20:35:17] [I] Load engine:
[08/30/2019-20:35:17] [I] Inputs format: fp32:CHW
[08/30/2019-20:35:17] [I] Outputs format: fp32:CHW
[08/30/2019-20:35:17] [I] Input build shapes: model
[08/30/2019-20:35:17] [I] === System Options ===
[08/30/2019-20:35:17] [I] Device: 0
[08/30/2019-20:35:17] [I] DLACore:
[08/30/2019-20:35:17] [I] Plugins:
[08/30/2019-20:35:17] [I] === Inference Options ===
[08/30/2019-20:35:17] [I] Batch: 8
[08/30/2019-20:35:17] [I] Iterations: 40 (200 ms warm up)
[08/30/2019-20:35:17] [I] Duration: 10s
[08/30/2019-20:35:17] [I] Sleep time: 0ms
[08/30/2019-20:35:17] [I] Streams: 1
[08/30/2019-20:35:17] [I] Spin-wait: Disabled
[08/30/2019-20:35:17] [I] Multithreading: Enabled
[08/30/2019-20:35:17] [I] CUDA Graph: Disabled
[08/30/2019-20:35:17] [I] Skip inference: Disabled
[08/30/2019-20:35:17] [I] Input inference shapes: model
[08/30/2019-20:35:17] [I] === Reporting Options ===
[08/30/2019-20:35:17] [I] Verbose: Disabled
[08/30/2019-20:35:17] [I] Averages: 100 inferences
[08/30/2019-20:35:17] [I] Percentile: 99
[08/30/2019-20:35:17] [I] Dump output: Disabled
[08/30/2019-20:35:17] [I] Profile: Disabled
[08/30/2019-20:35:17] [I] Export timing to JSON file:
[08/30/2019-20:35:17] [I] Export profile to JSON file:
[08/30/2019-20:35:19] [W] [TRT] Calling isShapeTensor before the entire network is constructed may result in an inaccurate result.
[08/30/2019-20:35:19] [W] [TRT] Tensor DataType is determined at build time for tensors not marked as input or output.
[08/30/2019-20:35:19] [W] [TRT] Calibrator is not being used. Users must provide dynamic range for all tensors that are not Int32.
trtexec: ../builder/cudnnBuilder2.cpp:1743: virtual std::vector<nvinfer1::query::RequirementsCombination> nvinfer1::builder::EngineTacticSupply::getSupportedFormats(const nvinfer1::builder::Node&): Assertion `!formats.empty()' failed.
