I use TensorRT 7.1.3 on Jetpack 4.5.1 TX2 with ONNX 1.6 but unsuccessful to convert weights from pytorch to ONNX and TensorRT. Please help me out.
The error as follows:
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
