Description
I’m having a look at the TensorRT C++ samples. They all compile and run fine, except one which is the sampleDynamicReshape. I get a “Exception thrown: read access violation. config._Mypair._Myval2-> was 0xFFFFFFFFFFFFFEE7.” on line 259 which does “config->setCalibrationProfile(profileCalib);”.
Would you guys have any idea why?
Environment
TensorRT Version: 7.2.1.6
GPU Type: GTX 1050 Ti
Nvidia Driver Version: 456.81
CUDA Version: 11.1
CUDNN Version: 8.0
Operating System + Version: Windows 10 build 18363
Baremetal or Container (if container which image + tag): Bare metal
Steps To Reproduce
- Load the solution file in Visual Studio
- Hit “F5”
Hi @The_Smith,
You issue has been noted.
Kindly allow us some time to check on this.
Hi @The_Smith,
Which visual studio version and cuDNN version are you using?
I’m using Visual Studio 2019 and cuDNN 8.0. All other samples are working with this setup.
Regards,
Smith
Hi @The_Smith,
We cant reproduce the issue at our end.
Can you please provide the below set of information -
PC CPU info and RAM info:
The url link for TensorRT / CUDA / cuDNN package:
Visual studio SDK version / Platform Toolset / C++ Language standard info like teh sample image
It will be useful to provide more screen snapshots or even screen videos to illustrate the issue.
Thanks for the information. I reviewed my setup parameters and I was able to find the error. The sample was loading the dlls from a previous TensorRT installation. All is well now.
Regards,
Smith
