I want to install tensorRT 7 on TX2i. Currently I have installed the cuda10.2.
I am unable to install TensorRT 7 on my Tx2i by attaching the file with the error message.
error tensort 7 (3.4 KB)
procomm@procomm-desktop:~$ python3 -m pip install --upgrade nvidia-tensorrt Defaulting to user installation because normal site-packages is not writeable Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com Collecting nvidia-tensorrt Downloading nvidia-tensorrt-0.0.1.dev4.tar.gz (3.8 kB) ERROR: Command errored out with exit status 1: command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-cvvtv2_4/nvidia-tensorrt_0ceecf51fae94981abca44ca785e1c00/setup.py'"'"'; __file__='"'"'/tmp/pip-install-cvvtv2_4/nvidia-tensorrt_0ceecf51fae94981abca44ca785e1c00/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-mk1o9x0o cwd: /tmp/pip-install-cvvtv2_4/nvidia-tensorrt_0ceecf51fae94981abca44ca785e1c00/ Complete output (15 lines): Traceback (most recent call last): File "<string>", line 1, in <module> File "/tmp/pip-install-cvvtv2_4/nvidia-tensorrt_0ceecf51fae94981abca44ca785e1c00/setup.py", line 150, in <module> raise RuntimeError(open("ERROR.txt", "r").read()) RuntimeError: ########################################################################################### The package you are trying to install is only a placeholder project on PyPI.org repository. This package is hosted on NVIDIA Python Package Index. This package can be installed as: ``` $ pip install nvidia-pyindex $ pip install nvidia-tensorrt ``` ########################################################################################### ---------------------------------------- WARNING: Discarding https://files.pythonhosted.org/packages/bf/88/324f19e3cc94c98421072c591ccd8170e0286d818a372eb38d45cc631119/nvidia-tensorrt-0.0.1.dev4.tar.gz#sha256=70f7ce9661852730482e51470f026d12149e53ad61acdf3d79cb5874d3cf677b (from https://pypi.org/simple/nvidia-tensorrt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output. ERROR: Could not find a version that satisfies the requirement nvidia-tensorrt ERROR: No matching distribution found for nvidia-tensorrt procomm@procomm-desktop:~$
What must be done to make it work?
thank you in advance for your help
Regards
Mr Owczarek
