TensorRT 8.6 Performance Issue in AGX Orin 32Gb
I’d like to reopen the case for this issue, based on my last post from tensorrt-8-6-not-running-properly-on-orin-nx-with-jetpack-6.
The generated TRT engines in JetPack6 only achieve half of the tensorrt engines inference speed in JetPack5.
  • Using host trtexec
  • Batch size of 2, warmup 100 avgruns 1000
Jetpack 5
Jetpack 6
This is the code to create the onnx models:
import torch
import timm
from timm.utils.model import reparameterize_model
model_names = [
    "fastvit_t8",
    "fastvit_t12",
    "fastvit_s12",
    "tiny_vit_5m_224",
    "tiny_vit_11m_224",
    "tiny_vit_21m_224",
    "mobilevit_xs",
    "mobilevit_s",
    "mobilevitv2_050",
    "repvit_m1_0",
    "repvit_m0_9",
    "mobileone_s0",
    "mobileone_s1",
    # other models are mobilesam/nanosam image encoder with 1024
resolution = [[440, 800], [640, 640], [800, 800], [1024, 1024]]
for model_name in model_names:
    for res in resolution:
        model = timm.create_model(model_name=model_name, pretrained=True, features_only=True).eval()
        x = torch.rand(2, 3, *res)
        model = reparameterize_model(model)
        torch.onnx.export(model, x, f"{model_name}_{res[0]}_{res[1]}.onnx", export_params=True, opset_version=15, do_constant_folding=True)
I use the following trtexec command to generate the engine and profiles:
/usr/src/tensorrt/bin/trtexec --onnx=path_to_onnx_file.onnx --saveEngine=path_to_engine_fp16/int8.engine --workspace=4096 --fp16 [--int8] --profilingVerbosity=detailed \
            --warmUp=100 --avgRuns=1000 --exportProfile=model_name_{precision}_profile.json --exportLayerInfo=model_name_{precision}_layer.json"
The scrip to generate the plots using notebook:
import os
import json
from glob import glob
import matplotlib.pyplot as plt
from matplotlib.ticker import (AutoMinorLocator, MultipleLocator)
time_profile = None
list_files = glob("*_profile.json")
# # using tuple unpacking for multiple Axes
fig, axs = plt.subplots(1, 2, sharex=True, figsize=(12, 6))
axs = axs.ravel()
latency_data_fp16 = []
latency_data_int8 = []
for file in list_files:
    filename = os.path.basename(file)
    component = filename.split("_")
    model_name = '_'.join(component[:-2])
    precision = component[-2]
    with open (file) as f:
        time_profile = json.loads(f.read())
    layer_time_profile = []
    for layer in time_profile[1:]:
        layer_time_profile.append((layer['name'], layer['averageMs']))
    total_time = sum(x[1] for x in layer_time_profile) # time in ms
    if precision == "fp16":
        latency_data_fp16.append((model_name, 1000/total_time))
    else:
        latency_data_int8.append((model_name, 1000/total_time))
latency_data_fp16 = sorted(latency_data_fp16, key=lambda x: x[1])
latency_data_int8 = sorted(latency_data_int8, key=lambda x: x[1])
names_fp16 = [d[0] for d in latency_data_fp16]
values_fp16 = [d[1] for d in latency_data_fp16]
names_int8 = [d[0] for d in latency_data_int8]
values_int8 = [d[1] for d in latency_data_int8]
axs[0].bar(names_fp16, values_fp16)
axs[0].tick_params(axis='x', rotation=90)
axs[0].title.set_text(f'FP16 Precision')
axs[0].set_ylabel('QPS')
axs[0].yaxis.grid(True)
# Change major ticks to show every 20.
axs[0].yaxis.set_major_locator(MultipleLocator(5))
axs[1].bar(names_int8, values_int8)
axs[1].tick_params(axis='x', rotation=90)
axs[1].title.set_text(f'INT8 Precision')
axs[1].set_ylabel('QPS')
axs[1].yaxis.grid(True)
axs[1].yaxis.set_major_locator(MultipleLocator(5))
plt.ylim([1, 50])
plt.show()
Thanks for reporting this.
We will try to reproduce this issue and update here.
Which nvpmodel do you use for benchmarking?
Have you used MAXN with jetson_clocks?
It’s hard to say because it’s been quite a while and I’ve reflashed the device several times. I think I used the standard 30W setting
Hey @AastaLLL, I mentioned the wrong device. It should be the AGX Orin 32Gb
We are trying to reproduce (takes time) internally.
Will let you know the following later.
Great, thanks. I also found that nvpmodel has something to do with tensorrt optimization. Different results between standard mode 2 (30W) and mode 3 (50W). Most likely the results of our previous experiments were caused by this but I’m not sure why, need your expertise to confirm this
Different CPU/GPU clock rate is used for the different nvpmodel.
Do you use the same nvpmodel to run the benchmark?
If not, would you mind giving it a try?
It seems like I was using a different nvpmodel version because at that time Jetpack 6 had just been installed and was immediately used. Just want to confirm, can different nvpmodel really affect the results? I will try it again after the Jetpack 6 production release
Yes, different clock rates will affect the GPU execution time.
We have run the benchmark result on both JetPack 5 and 6 under the MAXN setting.
No obvious performance difference is observed. Please double-check it.
