I have a ONNX file model that I want optimize with tensorRT.
I do the following :
import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.VERBOSE)
def Construction_Engine_ONNX(fichier):
builder = trt.Builder(TRT_LOGGER)
config = builder.create_builder_config()
builder.max_batch_size = 1 # Max BS = 1
config.max_workspace_size = 1000000000 # 1GB
config.set_flag(trt.BuilderFlag.TF32) # TF32
config.set_flag(trt.BuilderFlag.STRICT_TYPES)EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH) network = builder.create_network(EXPLICIT_BATCH) parser = trt.OnnxParser(network, TRT_LOGGER) with open(fichier, 'rb') as model: if not parser.parse(model.read()): return None else: return builder.build_serialized_network(network, config)
engine = Construction_Engine_ONNX(“file.onnx”)
serialized_engine = engine.serialize()
Get error : ‘NoneType’ object has no attribute ‘serialize’
With trtexec it works.
I I use builder.build_engine(network, config) instead of build_serialized_network I got :
/usr/lib/python3/dist-packages/ipykernel_launcher.py:30: DeprecationWarning: Use build_serialized_network instead.
Can you help me please ? Thanks a lot !
Link to ONNX file : Regression_Resnet18_saved_model.onnx - Google Drive
