TensorRT build fail with plugin on DW9.0 of Drive AGX
Hi, my code breaks when building model on DW9.0 of Drive AGX.
Error msg first:
ERROR: cuda/reformat.cu - Cuda Error in NCHWToNCHW: 48
Model can be built with kFLOAT, but breaks with kHALF.
More information if it helps discover the issue.
Relevant code hasn’t been modified for a long while. This is the first time it breaks like this.
Environments my code known to work fine:
Jetson TX2: Jetpack 3.2, 3.3, 4+
Jetson Xavier: Jetpack 4+
Drive AGX: Drive 8.0 TensorRT 4.x (not sure)
Also, I know my code works on different Jetsons with TensorRT v5.0.0 and v5.0.6 and v5.1.
However, it breaks with:
Same Drive AGX: Drive 9.0 TensorRT 5.0.3
I’m hoping to get some help to resolve this issue. Thx!
PS:
I’m not using any nvplugins. Nor am I using any new APIs of v5. My plugin extends IPluginExt to support both v4 and v5. (If I remember correctly, IPluginV2 is not available in v4.x)
