When I trying to convert a efficientnet-b0 model for trtexec to run. it failed. The model comes from nvidia github: DeepLearningExamples/PyTorch/Classification/ConvNets/efficientnet at master · NVIDIA/DeepLearningExamples · GitHub
The steps is as the following:
1# Download the pre-trained model: nvidia_efficientnet-b0_210412.onnx.
2# I run the " python model2onnx.py --arch efficientnet-b0 --pretrained-from-file nvidia_efficientnet-b0_210412.onnx -b 1 --trt True
onnx was generated,
3# Try trtexec, it failed with the command:
" trtexec --onnx=nvidia_efficientnet-b0_210412.onnx --explicitBatch --int8 --workspace=1024 --saveEngine=./effnet_b0_ws1024_gpu.engine"
The error said: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
terminate called after throwing an instance of ‘std::out_of_range’
what(): Attribute not found: axes
Aborted (core dumped)
I am using the NGC container as point out in the github readme page.
dpkg -l | grep nvinfer
ii libcublas-11-1 1.0 all libcublas packaging shim to work around libnvinfer package dependency issue
ii libcublas-dev-11-1 1.0 all libcublas-dev packaging shim to work around libnvinfer package dependency issue
ii libnvinfer-bin 7.2.2-1+cuda11.1 amd64 TensorRT binaries
ii libnvinfer-dev 7.2.2-1+cuda11.1 amd64 TensorRT development libraries and headers
ii libnvinfer-plugin-dev 7.2.2-1+cuda11.1 amd64 TensorRT plugin libraries and headers
ii libnvinfer-plugin7 7.2.2-1+cuda11.1 amd64 TensorRT plugin library
ii libnvinfer7 7.2.2-1+cuda11.1 amd64 TensorRT runtime libraries
not know how to get the Opset version, but I am using NGC containser with the command: nvidia-docker run --rm -it -v /mnt/imagenet:/imagenet --ipc=host nvidia_efficientnet
