I’m trying to implement the Caffe Axpy layer using custom layer plugin, based on sample codes such as samplePlugin.cpp and Face Recognition. While checking every step for debugging, however, I found the input parameters are not transported correctly. Actually, I’m not sure how to implement the constructor part. Here is a little part of my code:
class Axpy : public nvinfer::IPluginExt
public:
Axpy(){}
Axpy(const void* data, size_t size)
const int* d = static_cast<const int*> (data), *a = d;
dimsData = nvinfer1::DimsCHW{d[0], d[1], d[2]};
int getNbOutputs() const override
return 1;
Dims getOutputDimensions(int index, const Dims *inputs, int nbInputDims) override
assert(mNbInputChannels == inputs[0].d[0] * inputs[0].d[1] * inputs[0].d[2]);
return Dims3(mNbOutputChannels, 1, 1);
protected:
nvinfer1::DimsCHW dimsData;
// integration for serialization
class PluginFactory : public nvinfer1::IPluginFactory, public nvcaffeparser1::IPluginFactoryExt
public:
// caffe parser plugin implementation
bool isPlugin(const char *layerName) override
return isPluginExt(layerName);
bool isPluginExt(const char *layerName) override
return !strcmp(layerName, "conv2_1");
virtual nvinfer1::IPlugin* createPlugin(const char *layerName, const void *serialData, size_t serialLength) override
// there's no way to pass parameters through from the model definition, so we
// have to define it here explicitly
// TODO: do some relevant param pass, if any
//const caffe::LayerParameter lm;
mPlugin = std::unique_ptr<Axpy>(new Axpy(serialData, serialLength));
return mPlugin.get();
// deserialization plugin implementation
IPlugin* createPlugin(const char *layerName, const nvinfer1::Weights *weights, int nbWeights) override
assert(isPlugin(layerName));
// this plugin object is destroyed when engine is destroyed by calling
// IPluginExt::destroy()
assert(mPlugin.get() == nullptr);
mPlugin = std::unique_ptr<Axpy>(new Axpy());
// user application destroys plugin when it is safe to do so.
// should be done after consumers of plugin (like ICudaEngine) are destroyed.
void destroyPlugin() { mPlugin.reset(); }
std::unique_ptr<Axpy> mPlugin{ nullptr };
private:
const nvinfer1::Weights* w;
int nbWeights = 2;
int nbOutputChannels = 3;
However, this gives me assertion failure for the line
After checking the values, I found
inputs[0].d[0] = 256; inputs[0].d[1] = 0; inputs[0].d[2] = 0;
I doubt I did not build the constructor correctly and buffers are not storing values accordingly. Interestingly, the code always enters the createPlugin of form:
but never enters
What did I miss here? And how to pass those values correctly? Thanks.
