Greetings, everyone.
- Right now I am working on this project: GitHub - facebookresearch/sam2: The repository provides code for running inference with the Meta Segment Anything Model 2 (SAM 2), links for downloading the trained model checkpoints, and example notebooks that show how to use the model.
- I am using this guidance to export sam2.1 encoder[small] onnx model: GitHub - ibaiGorordo/ONNX-SAM2-Segment-Anything: Python scripts for the Segment Anythin 2 (SAM2) model in ONNX
- The exported onnx file can be successfully converted to TensorRT engine file;
- The hardware/software information is shown as following:
[04/20/2025-17:31:16] [I] === Device Information ===
[04/20/2025-17:31:16] [I] Available Devices:
[04/20/2025-17:31:16] [I] Device 0: “Orin” UUID: GPU-a00bb704-da56-555b-a79c-65a4e3662de8
[04/20/2025-17:31:16] [I] Selected Device: Orin
[04/20/2025-17:31:16] [I] Selected Device ID: 0
[04/20/2025-17:31:16] [I] Selected Device UUID: GPU-a00bb704-da56-555b-a79c-65a4e3662de8
[04/20/2025-17:31:16] [I] Compute Capability: 8.7
[04/20/2025-17:31:16] [I] SMs: 16
[04/20/2025-17:31:16] [I] Device Global Memory: 62840 MiB
[04/20/2025-17:31:16] [I] Shared Memory per SM: 164 KiB
[04/20/2025-17:31:16] [I] Memory Bus Width: 256 bits (ECC disabled)
[04/20/2025-17:31:16] [I] Application Compute Clock Rate: 1.3 GHz
[04/20/2025-17:31:16] [I] Application Memory Clock Rate: 1.3 GHz
[04/20/2025-17:31:16] [I] Note: The application clock rates do not reflect the actual clock rates that the GPU is currently running at.
[04/20/2025-17:31:16] [I] TensorRT version: 10.7.0
[04/20/2025-17:31:16] [I] Loading standard plugins
[04/20/2025-17:31:16] [I] [TRT] [MemUsageChange] Init CUDA: CPU +2, GPU +0, now: CPU 31, GPU 13403 (MiB)
[04/20/2025-17:31:18] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +928, GPU +749, now: CPU 1002, GPU 14197 (MiB)
[04/20/2025-17:31:18] [I] Start parsing network model.
Issue:
- I have successfully loaded the engine file and feed it with data using Python;
- However, the console outputs when running the inference:
2025-04-20 17:50:14.100165426 [W:onnxruntime:Default, scatter_nd.h:51 ScatterNDWithAtomicReduction] ScatterND with reduction==‘none’ only guarantees to be correct if indices are not duplicated.
2025-04-20 17:50:14.100240944 [W:onnxruntime:Default, scatter_nd.h:51 ScatterNDWithAtomicReduction] ScatterND with reduction==‘none’ only guarantees to be correct if indices are not duplicated. - Due to above issue, all values in all output tensors are 0.
- Online search doesn’t show too much helpful/valuable information to solve this issue.
If you have any clue/idea about this, could you please share it with me?
Thank you very much. :)
