import os
os.environ["CUDA_VISIBLE_DEVICES"]="0"
import tensorrt as trt
import cv2
import time
import numpy as np
import _init_paths
#import server modules
from flask import Flask, request, Response
import jsonpickle
import jsonpickle.ext.numpy as jsonpickle_numpy
jsonpickle_numpy.register_handlers()
from trt_demo import create_face_detector
face_detector = create_face_detector()
#initialize flask application
app = Flask(__name__)
#route http posts to this method
@app.route("/api/mtcnn", methods=["POST"])
def test():
r = request
nparr = np.fromstring(r.data, np.uint8)
#decode image
img = cv2.imdecode(nparr, cv2.IMREAD_COLOR)
#print("Shape of image is ", img.shape)
#detect face
all_boxes, landmarks = face_detector.detect_face(img)
response = {"bboxes" : all_boxes, "landmarks" : landmarks}
response_pickled = jsonpickle.encode(response)
return Response(response=response_pickled, status=200, mimetype="application/json")
if __name__ == "__main__":
app.run(host="0.0.0.0", port=8000)
Hi I built a HTTP server like shown above. When I send a image to the server, the model could be built but the inference failed like below:
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 2309, in __call__
return self.wsgi_app(environ, start_response)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 2295, in wsgi_app
response = self.handle_exception(e)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1741, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 2292, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1815, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1718, in handle_user_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1813, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1799, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/usr/src/app/mtcnn_trt/utils/server.py", line 125, in test
File "/usr/src/app/mtcnn_trt/lib/face_detector/mtcnn_face_detector.py", line 441, in detect_face
boxes, boxes_c, landmark = self.detect_pnet(img)
File "/usr/src/app/mtcnn_trt/lib/face_detector/mtcnn_face_detector.py", line 210, in detect_pnet
cls_cls_map, reg = self.pnet_predict(im_resized, scale_cnt)
File "/usr/src/app/mtcnn_trt/lib/face_detector/mtcnn_face_detector.py", line 191, in pnet_predict
cls_prob, bbox_pred, _ = engine.infer(np.transpose(img, (2, 0, 1)))
File "/usr/lib/python2.7/dist-packages/tensorrt/lite/engine.py", line 658, in infer
stream = cuda.Stream()
LogicError: explicit_context_dependent failed: invalid device context - no currently active context?
But if I try to detect for an image outside this app, it will be fine. Any advice would be greatly appreciated!
