Another issue I noticed is, I think polygraphy is not supported for Jetson Embedded Environment; I found that it failed to install its dependencies. Although I was able to install it on a host system. I need to deploy this model on one such Jetson device and I think Polygraphy wouldn’t suffice here.
Have you tried polygraphy tool mentioned above on your host and facing the same issue with new ONNX model ?
Thank you.
yes that’s exactly what I did and got the same errror.
Could you please share us issue repro new onnx model.
Thank you.
Could you please provide access.
Sorry for the delay but done so. Please check
We could reproduce the same error after trying polygraphy tool as well,
I think the issue here is that the K
value is computed at runtime, which is not supported by TRT.
Thank you.
So TensorRT+ONNX isn’t capable of solving this ?
Its currently not supported by TRT.
