I am following detectnet_v2 notebook to train a single class object detection model. I am able to train the
- train the initial pre-trained model
- validate the model,
- prune the model
- training the pruned model
- Validating the pruned model without any memory issues.
But when I try to perform deploy step
!mkdir -p $USER_EXPERIMENT_DIR/experiment_dir_final
# Removing a pre-existing copy of the etlt if there has been any.
import os
output_file=os.path.join(os.environ['USER_EXPERIMENT_DIR'],
"experiment_dir_final/resnet18_detector.etlt")
if os.path.exists(output_file):
os.system("rm {}".format(output_file))
!tlt-export detectnet_v2 \
-m $USER_EXPERIMENT_DIR/experiment_dir_retrain/weights/resnet18_detector_pruned.tlt \
-o $USER_EXPERIMENT_DIR/experiment_dir_final/resnet18_detector.etlt \
-k $KEY
I am getting below error.
2020-11-19 06:28:45.551169: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-11-19 06:28:45.551175: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-11-19 06:28:45.551245: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-11-19 06:28:45.551585: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-11-19 06:28:45.551894: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 4492 MB memory) â physical GPU (device: 0, name: GeForce GTX 1660 Ti, pci bus id: 0000:01:00.0, compute capability: 7.5)
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking [âoutput_cov/Sigmoidâ, âoutput_bbox/BiasAddâ] as outputs
[TensorRT] ERROR: âŚ/rtSafe/safeRuntime.cpp (25) - Cuda Error in allocate: 2 (out of memory)
[TensorRT] ERROR: âŚ/rtSafe/safeRuntime.cpp (25) - Cuda Error in allocate: 2 (GPU memory allocation failed during allocation of workspace. Try decreasing batch size.)
2020-11-19 06:29:30,029 [ERROR] modulus.export._tensorrt: Failed to create engine
File â/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.pyâ, line 521, in init
AssertionErrorDuring handling of the above exception, another exception occurred:
File â/usr/local/bin/tlt-exportâ, line 8, in
sys.exit(main())
File â/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.pyâ, line 185, in main
File â/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.pyâ, line 263, in run_export
File â/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.pyâ, line 505, in export
File â/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.pyâ, line 676, in init
File â/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.pyâ, line 529, in init
AssertionError: Parsing failed on line 521 in statement
⢠Hardware Platform (GPU)
⢠TLT container 2.0
⢠NVIDIA GPU Driver Version (440.1)
⢠Issue Type( questions)
