Thank you for replying, I am using Jetson Tx2 with jetpack 4.3. Below are additional details.
Linux distro and version:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION=“Ubuntu 18.04.4 LTS”
NAME=“Ubuntu”
VERSION=“18.04.4 LTS (Bionic Beaver)”
Nvidia driver version
CUDA version:
10.0.326
cudNN version:
7.6.3
Python 3.6.9
TensorRT 6.0.1
Mxnet: 1.6.0
Gluoncv: 0.7.0
Code (to create onnx file):
import mxnet as mx
import numpy as np
from mxnet.contrib import onnx as onnx_mxnet
import logging
import gluoncv as gcv
from gluoncv.utils import export_block
logging.basicConfig(level=logging.INFO)
net = gcv.model_zoo.get_model(‘cifar_resnet110_v1’, classes=10, pretrained=True)
export_block(‘cifar_resnet110_v1’, net, preprocess=True)
import glob
print(glob.glob(‘.json’) + glob.glob('.params’))
We will use the downloaded pre-trained model files (sym, params) and define input variables.
Downloaded input symbol and params files
sym = ‘./cifar_resnet110_v1-symbol.json’
params = ‘./cifar_resnet110_v1-0000.params’
input_shape = (1, 32, 32, 3)
Path of the output file
onnx_file = ‘./cifar_resnet110_v1.onnx’
Invoke export model API. It returns path of the converted onnx model
converted_model_path = onnx_mxnet.export_model(sym, params, [input_shape], np.float32, onnx_file)
from onnx import checker
import onnx
Load onnx model
model_proto = onnx.load_model(converted_model_path)
Check if converted ONNX protobuf is valid
checker.check_graph(model_proto.graph)
Code (to create tensorrt engine file):
import tensorrt.legacy as trt
import numpy as np
import time
from mxnet import gluon, nd, image
from mxnet.gluon.data.vision import transforms
from gluoncv import utils
import glob
model_path = ‘/home/sapphire/Desktop/cifar_resnet110_v1.onnx’
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
def build_engine(model_path):
with trt.Builder(TRT_LOGGER) as builder,
builder.create_network() as network,
trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.max_workspace_size = 1<<25
builder.max_batch_size = 1
with open(model_path, “rb”) as f:
parser.parse(f.read())
engine = builder.build_cuda_engine(network)
return engine
engine = build_engine(model_path)
trt.utils.write_engine_to_file(‘cifar_resnet110_v1.engine’, engine.serialize())
glob.glob(“*.engine”)
print(‘done’)
Code (to make inference with engine):
from tensorrt.legacy.lite import Engine
from tensorrt.legacy.infer import LogSeverity
import numpy as np
import pycuda.autoinit
TRT_LOGGER =trt.Logger(trt.Logger.WARNING)
url = ‘https://raw.githubusercontent.com/dmlc/web-data/master/gluoncv/classification/plane-draw.jpeg’
im_fname = utils.download(url)
img = image.imread(im_fname)
def transform(img):
transform_fn = transforms.Compose([
transforms.Resize(32),
transforms.CenterCrop(32),
transforms.ToTensor(),
transforms.Normalize([0.4914, 0.4822, 0.4465], [0.2023, 0.1994, 0.2010])
return transform_fn(img)
engine = Engine(PLAN=‘cifar_resnet110_v1.engine’)
img = transform(img)
pred = engine.infer(img.expand_dims(axis=0))
print(pred)
class_names = [‘airplane’, ‘automobile’, ‘bird’, ‘cat’, ‘deer’,
‘dog’, ‘frog’, ‘horse’, ‘ship’, ‘truck’]
ind = nd.argmax(pred, axis=1).astype(‘int’)
print(‘The input picture is classified as [%s], with probability %.3f.’% (class_names[ind.asscalar()], nd.softmax(pred)[0][ind].asscalar()))
I am still trying to understand how to utilise tensorrt, so pls I would greatly appreciate any feedback and advice if I am using it wrongly. Thank you
