Description
Hi all. I have converted a PyTorch model to trt directly in python, without using ONNX or trtexec (because it has some custom operations).
my python pseudo-code is as below, I used tsm model from this repo (tensorrtx/tsm/tsm_r50.py at master · wang-xinyu/tensorrtx · GitHub):
network = builder.create_network(
1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
num_segments=24
n_batch= 2
batch_segments = n_batch*num_segments
data = network.add_input(input_plob_name, data_type,
(batch_segments, 3, model_input_h, model_input_h))
conv1 = network.add_convolution(input=data,
num_output_maps=64,
kernel_shape=(7, 7),
kernel=np.asarray(
weight_map["conv1.weight"],
dtype="float32"),
bias=trt.Weights())
# add some layers here ...
fc1 = network.add_fully_connected(input=pool2.get_output(0),
num_outputs=output_size,
kernel=np.asarray(
weight_map['fc.weight'],
dtype="float32"),
bias=np.asarray(weight_map['fc.bias'],
dtype="float32"))
reshape = network.add_shuffle(fc1.get_output(0))
assert reshape
reshape.reshape_dims = (n_batch, num_segments, output_size)
reduce = network.add_reduce(reshape.get_output(0),
op=trt.ReduceOperation.AVG,
axes=2,
keep_dims=False)
assert reduce
softmax = network.add_softmax(reduce.get_output(0))
assert softmax
softmax.axes = 1
softmax.get_output(0).name = output_plob_name
network.mark_output(softmax.get_output(0))
config = builder.create_builder_config()
config.max_workspace_size = 1 << 30
builder.max_batch_size = n_batch
profile = builder.create_optimization_profile()
num_segments=24
n_batch=2
batch_segments= n_batch*num_segments # 2*24
profile.set_shape(
input_plob_name,
(num_segments, 3, 224, 224),
(batch_segments, 3, 224, 224),
logger = trt.Logger(trt.Logger.INFO)
config.add_optimization_profile(profile)
when I want to apply dynamic batch with min=24, opt=48, max=48, it gave me an error:
[TensorRT] ERROR: 4: [network.cpp::operator()::2733] Error Code 4: Internal Error (data: kMIN dimensions in profile 0 are [24,3,224,224] but input has static dimensions [48,3,224,224].)
Environment
docker image: nvcr.io/nvidia/tensorrt version==21.11-py3
TensorRT Version: tensorrt ==8.0.3.4
GPU Type: RTX 3060
Operating System + Version: UBUNTU 18.04
Python Version (if applicable): python 3.8.10
any help would be appreciated
