I’m using a Xavier AGX 64GB module, flashed with jetpack 4.6.1.
I am having trouble converting a ONNX model using:
trtexec --fp16 --onnx=/home/maxime/model.onnx --saveEngine=out.engine
Which output the following error:
[05/24/2022-03:19:03] [E] Error[2]: [utils.cpp::checkMemLimit::380] Error Code 2: Internal Error (Assertion upperBound != 0 failed. Unknown embedded device detected. Please update the table with the entry: {{1794, 8, 64}, 51309},)
[05/24/2022-03:19:03] [E] Error[2]: [builder.cpp::buildSerializedNetwork::609] Error Code 2: Internal Error (Assertion enginePtr != nullptr failed. )
[05/24/2022-03:19:03] [E] Engine could not be created from network
[05/24/2022-03:19:03] [E] Building engine failed
[05/24/2022-03:19:04] [E] Failed to create engine from model.
[05/24/2022-03:19:04] [E] Engine set up failed
This commands used to work well under an AGX 32GB.
Any idea ?
Software Version
- Jetpack 4.6.1
- TensoRT v8201
- cuda_10.2_r440.TC440_70.29663091_0
Hardware Platform
- Xavier AGX 64GB
