sys info:
os : ubuntu 16.04
tensorrt inference server : 1.15.0
container 19.06 {tensorflow 1.13.1, tensorrt 5.1.5.0}
CUDA Version 10.1.243
Driver Version: 418.87.01
failed to load 'demo' version 1: Not found: Op type not registered 'BatchMatMulV2' in binary running on fa60ca095bbf. Make sure the Op and Kernel are registered in the binary running in this process. Note that if you are loading a saved graph which used ops from tf.contrib, accessing (e.g.) `tf.contrib.resampler` should be done before importing the graph, as contrib ops are lazily registered when the module is first accessed.
could you help me to solve this issue?
