I have a TensorRT optimized engine with some convolutional layers at the end. Using a kernel size of 11 (in/out channels 128) takes significantly more time than using a kernel size of 3 (in/out channels 128). I am running on a Jetson Xavier NX board with JetPack 4.5.
I have attached the two log files with profiling at the end. The layers in question are called Conv_23 + Relu_24 and Conv_25 + Relu_26. The total inference time goes from about 40 ms to 2 ms.
Am I doing something wrong? I train my model using PyTorch; measuring inference time in Python gives roughly the same (~2 ms) for both the larger and smaller kernel sizes.
I have attached the log file created by trtexec in my original post. You can see the network architecture there; as well as the execution profile dump at the end of said log files.
My concern is regarding one single change, that makes such a huge difference in execution times of two convolutional layers. As I said in my original post, using a kernel size of 11 compared to a size of 3, the latency drops from 40 ms to 2 ms. I do not understand why, using a kernel size of 11 would be such a burden for the TensorRT optimized engine.
Given the same parameters of a Conv, the computation required by kernel size 11 is about 13.4x of kernel size 3. So the long running time of kernel size 11 should be expected in general (though we need to investigate in detail).
Hope this issue is not blocker for you.
If yes, please share us onnx model and issue reproduce steps to debug.
