TensorRT Installation problem
Description
I installed TensorRT and CUDNN on Windows for using with yoloV8.
Following nvidia documentation (zip installation): TensorRT installation documentation
But when I ran this code on Python3.11:
import tensorrt
print(tensorrt.__version__)
assert tensorrt.Builder(tensorrt.Logger())
this happens:
“nvinfer_builder_resource.dll” this file is located on “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\bin” and this location is added on system environment path.
what can I do for resolve this error.
Environment
TensorRT Version: 8.6.1.6
GPU Type: NVIDIA GeForce RTX 4060
Nvidia Driver Version: 536.40
CUDA Version: 12.1
CUDNN Version: 8.9.0.131
Operating System + Version: Windows 11
Python Version (if applicable): 3.11
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 2.1.1
Baremetal or Container (if container which image + tag):
Steps To Reproduce
It can be help you:
import torch
import tensorrt
print(torch.version.cuda)
print(torch.backends.cudnn.version())
Output:
8.6.1
12.1
8801
Installation steps for TensorRT:
https://docs.nvidia.com/deeplearning/tensorrt/archives/tensorrt-861/install-guide/index.html#installing-zip
Installation steps for CUDNN:
https://docs.nvidia.com/deeplearning/cudnn/install-guide/index.html#install-windows
Hi @aniksabbirserver ,
This looks like a CUDA incompatibility issue.
Can you please try with a clean setup and reinstall CUDA and follow the TRT installation steps.?
Can you please give me the compatible version of those so I can reinstall it with specific version:
TensorRT Version :
CUDA Version :
CUDNN Version :
PyTorch Version :
can you please update me some solution. I tried all latest versions. but still error happening.
I am stuck on it. please help me.
Apologies for delayed response.
Please find teh support matrix for compatible versions across.
