Hi, I am using as an example the script tf_to_trt.py (located at /usr/lib/python3.5/dist-packages/tensorrt/examples/tf_to_trt) to run the optimized inference using TensorRT 4. I am using a frozen graph model trained with Keras (TensorFlow backend), but getting the below errors:
Converting to UFF graph
Warning: No conversion function registered for layer: IteratorGetNext yet.
Converting as custom op IteratorGetNext IteratorGetNext
op: "IteratorGetNext"
input: "OneShotIterator"
attr {
key: "_output_shapes"
value {
list {
shape {
dim {
dim {
dim {
dim {
shape {
dim {
dim {
attr {
key: "output_shapes"
value {
list {
shape {
dim {
dim {
dim {
dim {
shape {
dim {
dim {
attr {
key: "output_types"
value {
list {
type: DT_FLOAT
type: DT_INT64
File "tf_to_trt_chest_bhavesh_model.py", line 188, in <module>
main()
File "tf_to_trt_chest_bhavesh_model.py", line 158, in main
uff_model = uff.from_tensorflow(tf_model, ["probs"])
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 120, in from_tenso rflow
name="main")
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 76, in convert_tf2uff_graph
uff_graph, input_replacements)
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 63, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes)
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 38, in convert_layer
fields = cls.parse_tf_attrs(tf_node.attr)
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 209, in parse_tf_attrs
for key, val in attrs.items()}
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 209, in <dictcomp>
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 204, in parse_tf_attr_value
return cls.convert_tf2uff_field(code, val)
File "/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 189, in convert_tf2uff_fiel d
'type': 'dtype', 'list': 'list'}[code]
KeyError: 'shape'
