TensorRT library call in python from virtualenv
Hi guys,
I was wondering if there was a way to link TensorRT library to a virtualenv to call it as “import tensorrt” ?
I’m on JetsonTX2 jetpack4.4 and obviously TensorRT is installed but I can’t call it from a python script from my virtualenv.
Any idea ?
FOUND IT.
You just have to add to PYTHONPATH in .bashrc the path to the file tensorrt.so.
It is normally installed in /usr/lib/python3.6/dist-packages/
So for me it was (inside the .bashrc file or you will have to execute the command each time you re-enter the virtualenv):
export PYTHONPATH=/usr/lib/python3.6/dist-packages:$PYTHONPATH
You can have the full explanation here.
