TensorRT-LLM + nvidia/Llama-3.3-70B-Instruct-NVFP4 = 5 tok/s
I ws expecting to see something around 15 to 18tok/s. Is there any tuning needed? This is what I’m doing:
cat << ‘EOF’ > /tmp/config.yml
enable_attention_dp: true
print_iter_log: true
cuda_graph_config:
enable_padding: false
max_batch_size: 1
kv_cache_config:
dtype: fp8
EOF
trtllm-serve “nvidia/Llama-3.3-70B-Instruct-NVFP4”
–max_batch_size 1
–max_num_tokens 4096
–max_seq_len 2048
–kv_cache_free_gpu_memory_fraction 0.75
–tp_size 1 --ep_size 1
–config /tmp/config.yml
How did you come up with that expectation?
Max memory bandwidth on Spark is 273 GB/s. This means that for 70B model in 4-bit quant you will get 273/35=7.8 t/s. And this is a theoretical maximum for a single Spark. In reality, the memory is slower on average, and there is additional overhead, so I’d expect around 6-7 t/s tops for this model.
Thanks for your answer… this clarifies everything.
Some other number for larger deployments
