Linux distro and version: Ubuntu16.04
GPU type:P4
nvidia driver version
CUDA version: 10
CUDNN version: 7.4.1
Python version [if using python]: 3.5
Tensorflow version: 1.12
TensorRT version: 5.02
If Jetson, OS, hw versions:NA
Describe the problem
While build tensorrt model with tf-trt 1.12, the exported model’s shape info is lost. The exported model could run on TRTIS, but if I change the frozen model to Savedmodel, it will cause error both on TRTIS and TF-serving.
https://github.com/tensorflow/tensorrt.git
just run the tensorrt/tftrt/examples/image-classification/image_classification.py with int8 parameter like the follow command and get the frozen model from graphs directory.
python image_classification.py --model resnet_v1_50 --data_dir /data/ImageNetVal/ --precision fp32 --batch_size=1 --use_trt
the one frozen from tensorrt:
Tensor(“input:0”, shape=(?, 224, 224, 3), dtype=float32)
Tensor(“logits:0”, dtype=float32)
and the native one:
Tensor(“logits:0”, shape=(?, 1001), dtype=float32)
the difference is the shape in logits from tensorrt have been lost.
script as follow:
import tensorflow as tf
from tensorflow.contrib import tensorrt as trt
import os
import shutil
graph_pb = ‘frozen_graph_resnet_v1_50_1_fp32_1.pb’
with tf.gfile.GFile(graph_pb, “rb”) as f:
graph_def = tf.GraphDef()
graph_def.ParseFromString(f.read())
sigs = {}
with tf.Session(graph=tf.Graph()) as sess:
for n in graph_def.node:
if n.name == “logits”:
print(n)
if n.name == “input”:
print(n)
