TensorRT memory consumption
I try to build YOLO11 segmentation engine with TensorRT 10.3.0.
I always receive error messages:
[TRT] /1/Reshape_10: IShuffleLayer with zeroIsPlaceHolder=true has reshape dimension at position 1 that might or might not be zero. TensorRT resolves it at runtime, but this may cause excessive memory consumption and is usually a sign of a bug in the network.
How to fix it?
Hi @June.Lin ,
This was a known bug in old release,
Would request you to pls try the latest, which should resolve the error.
