Hi! I am currently trying to transfer the tensorrt model from the server to my computer, and I don’t know if the graphic card on my computer will support the inference process.
The reason is that the tensorrt model set up on the server has enabled the mix-precision(float16 and int8 mode). So I wonder what the minimum requirement of the graphic card is(Titan V on the server) that allows the mix-precision model to do the inference.
Environment
*TensorRT Version: 7.2.2.3 GPU Type: server: Titan V; PC:GTX1050 Nvidia Driver Version: 450.51.05 CUDA Version: 11.0 CUDNN Version: 8.0.4 Operating System + Version: Ubuntu 18.04 Python Version (if applicable): 3.7 TensorFlow Version (if applicable): 1.14 PyTorch Version (if applicable): Baremetal or Container (if container which image + tag):
Thank you for your reply!
I have checked the fourth section "Hardware and precision"in the link: Support Matrix :: NVIDIA Deep Learning TensorRT Documentation.
I found that the int8 mode requires at least 6.1 compute capability (Tesla P4), so for my own PC, if I use general GTX graphic card, I would guess the least requirement is GTX1060?
