Description
I’m trying to run superglue with TensorRT,it returns dynamic shape output.It’s run without any error but the result is always NaN.When i set my output shape upper than expected shape i got NaN for that expected shape and 0.0 for others.
Environment
TensorRT Version: 8.6.2.3
GPU Type: Nvidia Jetson Orin nx (16Gb ram)
Nvidia Driver Version: Jetpack 6.0 DP
CUDA Version: 12.02.140
CUDNN Version: 8.9.4.25
Operating System + Version: Ubuntu 22.04 LTS
Python Version (if applicable): 3.10.12
Relevant Files
Superglue pytorch implementation: GitHub - magicleap/SuperGluePretrainedNetwork: SuperGlue: Learning Feature Matching with Graph Neural Networks (CVPR 2020, Oral)
convert_to_onnx: SuperPoint-SuperGlue-TensorRT/convert2onnx/convert_superglue_to_onnx.py at main · yuefanhao/SuperPoint-SuperGlue-TensorRT · GitHub
build_engine.py:
import tensorrt as trt
# Initialize TensorRT logger and builder
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
builder = trt.Builder(TRT_LOGGER)
config = builder.create_builder_config()
# Set cache
cache = config.create_timing_cache(b"")
config.set_timing_cache(cache, ignore_mismatch=False)
flag = 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
network = builder.create_network(flag)
parser = trt.OnnxParser(network, TRT_LOGGER)
path_onnx_model = "/home/jetson/a/TensorRT/trt/superglue_outdoor_sim_int32.onnx"
with open(path_onnx_model, "rb") as f:
if not parser.parse(f.read()):
print(f"ERROR: Failed to parse the ONNX file {path_onnx_model}")
for error in range(parser.num_errors):
print(parser.get_error(error))
inputs = [network.get_input(i) for i in range(network.num_inputs)]
outputs = [network.get_output(i) for i in range(network.num_outputs)]
print(outputs[0])
profile = builder.create_optimization_profile()
min_shape = [1, 1, 2]
opt_shape = [1, 1024, 2]
max_shape = [1, 2048, 2]
profile.set_shape(inputs[0].name, min_shape, opt_shape, max_shape)
min_shape = [1, 1]
opt_shape = [1, 1024]
max_shape = [1, 2048]
profile.set_shape(inputs[1].name, min_shape, opt_shape, max_shape)
min_shape = [1, 256, 1]
opt_shape = [1, 256, 1024]
max_shape = [1, 256, 2048]
profile.set_shape(inputs[2].name, min_shape, opt_shape, max_shape)
profile.set_shape(inputs[3].name, min_shape, opt_shape, max_shape)
min_shape = [1, 1]
profile.set_shape(inputs[4].name, min_shape, opt_shape, max_shape)
profile.set_shape(inputs[5].name, min_shape, opt_shape, max_shape)
config.add_optimization_profile(profile)
config.get_calibration_profile()
# Check if fast Half is avaliable
# print(builder.platform_has_fast_fp16)
config.set_flag(trt.BuilderFlag.FP16)
# Build engine
engine_bytes = builder.build_serialized_network(network, config)
engine_path = "superglue.engine"
with open(engine_path, "wb") as f:
f.write(engine_bytes)
inference.py:
import numpy as np
from cuda import cuda, cudart
import ctypes
from typing import Optional, List
import torch
def check_cuda_err(err):
if isinstance(err, cuda.CUresult):
if err != cuda.CUresult.CUDA_SUCCESS:
raise RuntimeError("Cuda Error: {}".format(err))
if isinstance(err, cudart.cudaError_t):
if err != cudart.cudaError_t.cudaSuccess:
raise RuntimeError("Cuda Runtime Error: {}".format(err))
else:
raise RuntimeError("Unknown error type: {}".format(err))
def cuda_call(call):
err, res = call[0], call[1:]
check_cuda_err(err)
if len(res) == 1:
res = res[0]
return res
class HostDeviceMem:
"""Pair of host and device memory, where the host memory is wrapped in a numpy array"""
def __init__(self, size: int, dtype: np.dtype):
nbytes = size * dtype.itemsize
host_mem = cuda_call(cudart.cudaMallocHost(nbytes))
pointer_type = ctypes.POINTER(np.ctypeslib.as_ctypes_type(dtype))
self._host = np.ctypeslib.as_array(ctypes.cast(host_mem, pointer_type), (size,))
self._device = cuda_call(cudart.cudaMalloc(nbytes))
self._nbytes = nbytes
@property
def host(self) -> np.ndarray:
return self._host
@host.setter
def host(self, arr: np.ndarray):
if arr.size > self.host.size:
raise ValueError(
f"Tried to fit an array of size {arr.size} into host memory of size {self.host.size}"
#np.copyto(self.host[:arr.size], arr.flat, casting='safe')
np.copyto(self.host[:arr.size], arr.flat)
@property
def device(self) -> int:
return self._device
@property
def nbytes(self) -> int:
return self._nbytes
def __str__(self):
return f"Host:\n{self.host}\nDevice:\n{self.device}\nSize:\n{self.nbytes}\n"
def __repr__(self):
return self.__str__()
def free(self):
cuda_call(cudart.cudaFree(self.device))
cuda_call(cudart.cudaFreeHost(self.host.ctypes.data))
# Allocates all buffers required for an engine, i.e. host/device inputs/outputs.
# If engine uses dynamic shapes, specify a profile to find the maximum input & output size.
def allocate_buffers(engine: trt.ICudaEngine, inputs_shape):
inputs = []
outputs = []
bindings = []
stream = cuda_call(cudart.cudaStreamCreate())
tensor_names = [engine.get_tensor_name(i) for i in range(engine.num_io_tensors)]
print("Tensor Names:", tensor_names)
for binding in tensor_names:
if engine.get_tensor_mode(binding) == trt.TensorIOMode.INPUT:
# Correctly an input
shape = engine.get_binding_shape(binding)
print("Input Shape for binding index", binding, ":", shape)
else:
# It's an output, handle accordingly
print("Output at binding index", binding, ":", shape)
for shape, binding in zip(inputs_shape, tensor_names):
size = trt.volume(shape)
#dtype = np.float32
# Get tensor data type
dtype = np.dtype(trt.nptype(engine.get_tensor_dtype(binding)))
print(dtype)
# Allocate host and device buffers
bindingMemory = HostDeviceMem(size, dtype)
# Append the device buffer to device bindings.
bindings.append(int(bindingMemory.device))
# Append to the appropriate list.
inputs.append(bindingMemory)
else:
print("injayim")
print(dtype)
outputs.append(bindingMemory)
# for binding in tensor_names:
# # Debug: Print tensor name and mode
# print("Tensor:", binding)
# print("Mode:", engine.get_tensor_mode(binding))
# # Get tensor shape
# shape = engine.get_binding_shape(binding) if profile_idx is None else engine.get_tensor_profile_shape(binding, profile_idx)[-1]
# print("injast" , shape)
# #shape = engine.get_tensor_profile_shape(binding, profile_idx)[-1]
# print("Shape:", shape)
# # Ensure shape is valid
# shape_valid = np.all([s >= 0 for s in shape])
# if not shape_valid and profile_idx is None:
# raise ValueError(f"Binding {binding} has dynamic shape, " +\
# "but no profile was specified.")
# # Calculate buffer size
# size = trt.volume(shape)
# if engine.has_implicit_batch_dimension:
# print(engine.max_batch_size)
# size *= engine.max_batch_size
# print("Buffer Size:", size)
# # Get tensor data type
# dtype = np.dtype(trt.nptype(engine.get_tensor_dtype(binding)))
# # Allocate host and device buffers
# bindingMemory = HostDeviceMem(size, dtype)
# # Append the device buffer to device bindings.
# bindings.append(int(bindingMemory.device))
# # Append to the appropriate list.
# if engine.get_tensor_mode(binding) == trt.TensorIOMode.INPUT:
# inputs.append(bindingMemory)
# else:
# outputs.append(bindingMemory)
return inputs, outputs, bindings, stream
# Frees the resources allocated in allocate_buffers
def free_buffers(inputs: List[HostDeviceMem], outputs: List[HostDeviceMem], stream: cudart.cudaStream_t):
for mem in inputs + outputs:
mem.free()
cuda_call(cudart.cudaStreamDestroy(stream))
# Wrapper for cudaMemcpy which infers copy size and does error checking
def memcpy_host_to_device(device_ptr: int, host_arr: np.ndarray):
nbytes = host_arr.size * host_arr.itemsize
cuda_call(cudart.cudaMemcpy(device_ptr, host_arr, nbytes, cudart.cudaMemcpyKind.cudaMemcpyHostToDevice))
def memcpy_device_to_host(host_arr: np.ndarray, device_ptr: int):
cuda_call(cudart.cudaMemcpy(host_arr, device_ptr, nbytes, cudart.cudaMemcpyKind.cudaMemcpyDeviceToHost))
def _do_inference_base(inputs, outputs, stream, execute_async):
# Transfer input data to the GPU.
kind = cudart.cudaMemcpyKind.cudaMemcpyHostToDevice
[cuda_call(cudart.cudaMemcpyAsync(inp.device, inp.host, inp.nbytes, kind, stream)) for inp in inputs]
# Run inference.
execute_async()
# Transfer predictions back from the GPU.
kind = cudart.cudaMemcpyKind.cudaMemcpyDeviceToHost
[cuda_call(cudart.cudaMemcpyAsync(out.host, out.device, out.nbytes, kind, stream)) for out in outputs]
# Synchronize the stream
cuda_call(cudart.cudaStreamSynchronize(stream))
# Return only the host outputs.
return [out.host for out in outputs]
# This function is generalized for multiple inputs/outputs.
# inputs and outputs are expected to be lists of HostDeviceMem objects.
def do_inference(context, bindings, inputs, outputs, stream, batch_size=1):
def execute_async():
context.execute_async(batch_size=batch_size, bindings=bindings, stream_handle=stream)
return _do_inference_base(inputs, outputs, stream, execute_async)
# This function is generalized for multiple inputs/outputs for full dimension networks.
def do_inference_v2(context, bindings, inputs, outputs, stream):
context.execute_async_v2(bindings=bindings, stream_handle=stream)
kpts0 = np.random.randint(0,255,(1,14,2))/255
scores0 = np.random.randint(0,255,(1,1293))/255
desc0 = np.random.randint(0,255,(1,256,1293))/255
kpts1 = np.random.randint(0,255,(1,1246,2))/255
scores1 = np.random.randint(0,255,(1,1246))/255
desc1 = np.random.randint(0,255,(1,256,1246))/255
# # Example output for keypoints, scores, and descriptors for Image 0
# kpts0 = np.array([[[10, 20], [30, 40], [50, 60]]]) # Example keypoints for Image 0
# scores0 = np.array([[0.9, 0.8, 0.7]]) # Example scores for keypoints in Image 0
# desc0 = np.random.rand(1, 256, 3) # Example descriptors for keypoints in Image 0
# print(kpts0.shape, scores0.shape, desc0.shape)
# # Example output for keypoints, scores, and descriptors for Image 1
# kpts1 = np.array([[[15, 25], [35, 45], [55, 65]]]) # Example keypoints for Image 1
# scores1 = np.array([[0.85, 0.75, 0.65]]) # Example scores for keypoints in Image 1
# desc1 = np.random.rand(1, 256, 3) # Example descriptors for keypoints in Image 1
# print(kpts1.shape, scores1.shape, desc1.shape)
kpts0 = torch.load('/home/jetson/Downloads/keypoints.pt', map_location = torch.device('cpu'))
kpts0 = kpts0.numpy()
scores0 = torch.load('/home/jetson/Downloads/keypoint_scores.pt', map_location = torch.device('cpu'))
scores0 = scores0.numpy()
desc0 = torch.load('/home/jetson/Downloads/descriptors.pt', map_location = torch.device('cpu'))
desc0 = desc0.numpy()
desc0 = desc0.transpose(0, 2, 1)
kpts1 = torch.load('/home/jetson/Downloads/keypoints.pt', map_location = torch.device('cpu'))
kpts1 = kpts1.numpy()
scores1 = torch.load('/home/jetson/Downloads/keypoint_scores.pt', map_location = torch.device('cpu'))
scores1 = scores1.numpy()
desc1 = torch.load('/home/jetson/Downloads/descriptors.pt', map_location = torch.device('cpu'))
desc1 = desc1.numpy()
desc1 = desc1.transpose(0, 2, 1)
# permute_descriptor = descriptors[0].permute(1, 0)
# kpts0 = torch.unsqueeze(keypoints[0], 0).numpy()
# scores0 = torch.unsqueeze(scores[0], 0).numpy()
# desc0 = torch.unsqueeze(permute_descriptor, 0).numpy()
# kpts1 = torch.unsqueeze(keypoints[0], 0).numpy()
# scores1 = torch.unsqueeze(scores[0], 0).numpy()
# desc1 = torch.unsqueeze(permute_descriptor, 0).numpy()
# kpts0 = kpts0.astype(np.float32) # Ensure data is in float32 format
# scores0 = scores0.astype(np.float32) # Ensure data is in float32 format
# desc0 = desc0.astype(np.float32) # Ensure data is in float32 format
# kpts1 = kpts1.astype(np.float32) # Ensure data is in float32 format
# scores1 = scores1.astype(np.float32) # Ensure data is in float32 format
# desc1 = desc1.astype(np.float32) # Ensure data is in float32 format
# Function to load a TensorRT engine from a file
def load_engine(engine_file_path):
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
with open(engine_file_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
return runtime.deserialize_cuda_engine(f.read())
# Load the engine
engine_file_path = "/home/jetson/a/TensorRT/superglue.engine"
engine = load_engine(engine_file_path)
context = engine.create_execution_context()
input_binding_index = engine.get_binding_index("keypoints_0")
context.set_binding_shape(input_binding_index, kpts0.shape)
input_binding_index = engine.get_binding_index("scores_0")
context.set_binding_shape(input_binding_index, scores0.shape)
input_binding_index = engine.get_binding_index("descriptors_0")
context.set_binding_shape(input_binding_index, desc0.shape)
input_binding_index = engine.get_binding_index("keypoints_1")
context.set_binding_shape(input_binding_index, kpts1.shape)
input_binding_index = engine.get_binding_index("scores_1")
context.set_binding_shape(input_binding_index, scores1.shape)
input_binding_index = engine.get_binding_index("descriptors_1")
context.set_binding_shape(input_binding_index, desc1.shape)
inputs_shape = [kpts0.shape, scores0.shape, desc0.shape, kpts1.shape, scores1.shape, desc1.shape, (1, 100, 100)]
# y = engine.get_binding_index("scores")
# print("here", context.get_tensor_shape(0))
# Allocate memory for inputs and outputs
print("before allocate")
inputs, outputs, bindings, stream = allocate_buffers(engine, inputs_shape)
print('outputs: ', outputs)
print("after allocate")
output_data = do_inference_v2(context, bindings, inputs, outputs, stream)
# Process the output (example)
print("Output:", output_data[0])
# Free allocated memory
free_buffers(inputs, outputs, stream)
