TensorRT model export/inference
I trained RT-DETR thanks to modifying the rtdetr_detection_distillation.ipynb from tao tutorials. I trained the teacher model and succesfully distilled the student model. The student as well as the teacher model performed with over 80 mAP50 on the evaluation dataset.
But when i convert the student model to onnx and then to tensorrt engine and run inference as defined in the notebook, i get the result with blank labels even though something should be detected.
these are my onnx generation specs:
specs[“dataset”][“batch_size”] = 8 #If OOM error, decrease batch size
specs[“dataset”][“workers”] = 4
specs[“dataset”][“remap_mscoco_category”] = False
specs[“dataset”][“num_classes”] = num_classes + 1
specs[“dataset”][“augmentation”][“eval_spatial_size”] = [960, 640]
specs[“dataset”][“augmentation”][“train_spatial_size”] = [960, 640]
specs[“model”][“backbone”] = “convnext_tiny”
specs[“model”][“train_backbone”] = True
specs[“model”][“return_interm_indices”] = [1,2,3]
specs[“model”][“dec_layers”] = 6
specs[“model”][“enc_layers”] = 1
specs[“model”][“num_queries”] = 300
specs[“export”][“input_width”] = 960
specs[“export”][“input_height”] = 640
print(json.dumps(specs, sort_keys=True, indent=4))
this my spec for onnx to tensorrt
specs[“gen_trt_engine”][“tensorrt”][“data_type”] = “FP16”
inference spec:
specs[“dataset”][“batch_size”] = 1 #If OOM error, decrease batch size
specs[“inference”][“input_width”] = 960
specs[“inference”][“input_height”] = 640
specs[“inference”][“outline_width”] = 5
specs[“inference”][“color_map”] = {}
specs[“inference”][“color_map”][“crack”] = “red”
specs[“inference”][“color_map”][“pothole”] = “blue”
what could cause this? i do not think it is the problem of the model as the pth model performed well on evaluation dataset.
Thank you for any insigth
while exporting to onnx i get TracerWarnings: /usr/local/lib/python3.12/dist-packages/timm/models/layers/_init_.py:48: FutureWarning: Importing from timm.models.layers is deprecated, please import via timm.layers
warnings.warn(f"Importing from {_name_} is deprecated, please import via timm.layers", FutureWarning)
sys:1: UserWarning:
‘spec.yaml’ is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See Automatic schema-matching | Hydra for migration instructions.
/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/core/hydra/hydra_runner.py:110: UserWarning:
_run_hydra(
/usr/local/lib/python3.12/dist-packages/hydra/_internal/hydra.py:119: UserWarning: Future Hydra versions will no longer change working directory at job runtime by default.
See Changes to job's runtime working directory | Hydra for more information.
ret = run_job(
Export results will be saved at: /results/5d554949-36a6-4cbb-b8e1-942438fb457b/export
e[38;20m2025-11-06 07:21:57,516 - [TAO Toolkit] - INFO - Creating RT-DETR model from config for task: export, model_path: /results/5d554949-36a6-4cbb-b8e1-942438fb457b//results/2282d1ee-b1e3-4c3e-a161-929ae383dba2/distill/model_epoch_239.pth (model.py:58)e[0m
e[38;20m2025-11-06 07:21:57,516 - [TAO Toolkit] - INFO - Loading RT-DETR model from checkpoint: /results/5d554949-36a6-4cbb-b8e1-942438fb457b//results/2282d1ee-b1e3-4c3e-a161-929ae383dba2/distill/model_epoch_239.pth (model.py:102)e[0m
e[38;20m2025-11-06 07:21:58,479 - [TAO Toolkit] - INFO - RT-DETR model loaded from checkpoint successfully. (model.py:110)e[0m
/usr/local/lib/python3.12/dist-packages/torch/nn/functional.py:6178: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
embed_dim == embed_dim_to_check
/usr/local/lib/python3.12/dist-packages/torch/nn/functional.py:6338: TracerWarning: Converting a tensor to a Python float might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
q_scaled = q * math.sqrt(1.0 / float(E))
/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/rtdetr_decoder.py:379: TracerWarning: torch.tensor results are registered as constants in the trace. You can safely ignore this warning if you use this function to create tensors out of constant variables that would be the same every time you call this function. In any other case, this might cause the trace to be incorrect.
level_start_index = torch.tensor(level_start_index, dtype=torch.int64, device=proj_feats[0].device)
/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/deformable_detr/model/ops/modules.py:134: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
e[38;20m2025-11-06 07:22:05,047 - [TAO Toolkit] - INFO - ONNX file stored at /results/5d554949-36a6-4cbb-b8e1-942438fb457b/model.onnx (export.py:193)e[0m
/usr/lib/python3.12/tempfile.py:1075: ResourceWarning: Implicitly cleaning up <TemporaryDirectory ‘/tmp/tmpoats267v’>
_warnings.warn(warn_message, ResourceWarning)
I managed to run evaluation directly on the exported engine with opset 18 and different precisions, evalluation gives results such as
Average Recall     (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.682AP: 0.296830177
AP50: 0.516228199
AP75: 0.307368338
APl: 0.455235362
APm: 0.214824483
APs: 0.005592352
ARl: 0.682352960
ARm: 0.369892478
ARmax1: 0.307692319
ARmax10: 0.446153849
ARmax100: 0.482248515
ARs: 0.087499999
Finished evaluation.
so obviously the model works, but when running inference i get only blank label files, no detections
This problem was solved by adding entries to the label_map.txt, what i figured out was, that when i trained the rt detr model with category_id = 0, the according label_map entry had to be on the second row.
But deepstream inference didn’t work afterwards, so I retrained the model with category_id=1, inference then ran on deepstream as expected, propably because 0 is reserverd for background. But to run the inference from tao notebook succesfully, I had to put the according name in label_map on the third row . WTF ..
Anyway inference than ran on TENSORRT but with a significant performance drop compared to the non-exported pytorch model. I will probably start a new thread on the export problem.
Hi @samanek,
Glad to hear you resolved the blank output issue!
The “Performance Drop” (Accuracy Loss) You mentioned a significant drop compared to the PyTorch model (your logs show AP ~0.29 vs the expected ~0.80). This is very likely caused by FP16 precision instability. Transformer-based models like RT-DETR can be sensitive to FP16 quantization, where small activation values in the attention layers “underflow” to zero or lose necessary precision.
You may Try re-generating the TensorRT engine with data_type: "FP32".
If the accuracy returns to ~0.80 mAP, you confirm it is a precision issue.
Thank you.
Hi @samanek , Is this issue the same as TensorRT RT-Detr model conversion precision loss? If yes, we already narrow down the engine issue. The evaluation result are the same between pytorch model and TensorRT engine. Currently, we are tracking on if it is related to FTMS.
Hi, yes, i opened a separate issue on the precision loss problem, where we already narrowed down the engine issue. Thank you very much for your insight though.
