Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
other
I deployed a model on cuda11.4-trt8.4.11-int8-drive_orin-gpu platform, but the memory footprint is up to 3.7GB. Even if I cut down the network structure and the output branch, I can’t effectively reduce it. Meanwhile another model with similar size and same input shape has a memory footprint of only 700MB. When I set “tactic_sources” as “CUBLAS”, the memory footprint dropped from 3.7GB to 2.2GB, and this strategy doesn’t work with normal models.
Do you have any idea that why the model uses so much memory and how to reduce it?
Dear @liuhaomin1,
Do you mean the memory consumption is more when building model using trtexec or final engine file?
I mean the model should not take up such memory during the inference on 11.4-trt8.4.11-int8-drive_orin-gpu platform.Even when I cut down the model to a small size, halve the input size and output nothing,the consumption is still high. So there must be something taking up memory that has nothing to do with the model structure.
Dear @liuhaomin1,
Does Developer Guide :: NVIDIA Deep Learning TensorRT Documentation helps?
I got another error this time when use this command:
trtexec --onnx=xxx.onnx ...... --useDLACore=1 ....
as u can see from the image. Does this mean my device only have 1 DLACore?
Dear @liuhaomin1,
May I know if you are using DRIVE AGX Orin devkit? I could use useDLACore=1
on my target.
of host-side overheads or data transfers.
[10/21/2022-10:37:21] [V] Enqueue Time: the host latency to enqueue a query. If this is longer than GPU Compute Time, the GPU may be under-utilized.
[10/21/2022-10:37:21] [V] H2D Latency: the latency for host-to-device data transfers for input tensors of a single query.
[10/21/2022-10:37:21] [V] D2H Latency: the latency for device-to-host data transfers for output tensors of a single query.
[10/21/2022-10:37:21] [V] Latency: the summation of H2D Latency, GPU Compute Time, and D2H Latency. This is the latency to infer a single query.
[10/21/2022-10:37:21] [I]
&&&& PASSED TensorRT.trtexec [TensorRT v8412] # ./trtexec --onnx=/tensorrt/data/mnist.onnx --useDLACore=1 --verbose --allowGPUFallback
Please use text messages instead of images in post to be able to search by others in community. Thank you
