I test yolov3 with tensorrt and witout tensorrt, I found the speed of backbone is no difference. I check my code is no problem, I guess the problem from model. Because the resnet50 can speed up with tensorrt
you can get test project from https://github.com/linssswww/bak_code
this is my envinronment and hardware:
1080Ti
cuda10.1
cudnn 7.5.1
ubuntu 16.04
tensorrt 5.1.5.0
pytorch 1.1.0
somebody meet same the issue
https://devtalk.nvidia.com/default/topic/1045913/tensorrt/no-improvement-in-fps-yolov3/post/5367749/#5367749
Hey dude, how do you port yolov3 to TensorRT runtime? I simply use a pytorch ver. of yolov3 and export it to onnx, I hope to build a TensorRT engine from the exported onnx model but failed. Seems that TensorRT does not support some operations of yolov3. Could you provide some insights into reimpl yolov3 with TRT?
I actually originally started with a pytorch yolov3.
Then i spent some time using the examples in tensorRT to convert yolov3 --> ONNX --> TensorRT
and it works :)
but sadly i got worse results than the pytorch implementation which was disappointing.
as far as im aware its only the yolo layer that isnt support but trt should optimise the other layers
this was on a gtx 1050 ti
Regards Andrew
Would recommend to try latest TRT version and let us know if the issue persists on the newer TensorRT releases.
