TensorRT nvinfer1::ICudaEngine deserializeCudaEngine not fast
Description
I’m using TensorRT to speed up a deep learning model during inference, we are really care about the delay between “starting the program” and “getting the first inference result”.
According to our experiment, the “nvinfer1::createInferRuntime” and “deserializeCudaEngine” take too much time, over 3 seconds, it is extremely long compared to the inference time which is only about 20ms long.
This is the profiling for the first model:
createInferRuntime: 1300ms
deserializeCudaEngine: 2300ms
This is the profiling for the second model(Same model, but difference TensorRT instance):
createInferRuntime: 0.5ms
deserializeCudaEngine: 140ms
So I guess much of the time in createInferRuntime and deserializeCudaEngine is spent on TensorRT runtime context preparation. Is there any way to speed up the initialization? We need to get the first result in shorter time, for example, 2 seconds.
Environment
TensorRT Version: 8.0.1.6
Type: Xavier NX
Jetpack Version: 4.6 [L4T 32.6.1]
CUDA Version: 10.2.300
CUDNN Version: 8.2.1.32
Relevant Files
like as follows:
This looks like a Jetson issue. Please refer to the below samples in case useful.
For any further assistance, we will move this post to to Jetson related forum.
Thanks for your response.
I can get right result from TensorRT before this, now I’m looking for a faster way to initialize our program, but TensorRT takes much time to createInferRuntime and deserializeCudaEngine.
Could you please let us know how big the model is?
Also please try on the latest TensorRT version and let us know if you still face this issue.
Thank you.
According to our experiment, the time that deserializeCudaEngine take in first times, have no relevance to mode size.
This is the profiling for two models(1st):
deserializeCudaEngine: 2300ms(model size: 26MB)
deserializeCudaEngine: 2300ms(model size: 11MB)
This is the profiling for two models(2nd):
deserializeCudaEngine: 140ms(model size: 26MB)
deserializeCudaEngine: 68ms(model size: 11MB)
Do you have the same problem?
Thank you for sharing.
Also please try on the latest TensorRT version and let us know if you still face this issue for better guidance.
According to our experiment, the time spent in deserializeCudaEngine(2300ms) and deserializeCudaEngine(1300ms) is independent of the TensorRT version (8.0.1.6 and 8.4.1.5).
