Description
I am trying to import FasterRCNN from ONNX to TensorRT and I recieved a parsing error in the resize operation.
Environment
TensorRT Version: 7.0.0.11
GPU Type: GeForce RTX 2070 Super
Nvidia Driver Version: 441.87
CUDA Version: 10.2
CUDNN Version: 7.6.5.32
Operating System + Version: Windows 10
Python Version (if applicable): -
TensorFlow Version (if applicable): -
PyTorch Version (if applicable): -
Baremetal or Container (if container which image + tag): -
ONNX version: 1.5
Opset version: 10
Steps To Reproduce
I am trying to import Faster RCNN model from ONNX to TensorRT. When I parse the model I get the following error while reading an operation:
UNKNOWN: ModelImporter.cpp:107: Parsing node: 415 [Resize]
UNKNOWN: ModelImporter.cpp:123: Searching for input: 388
UNKNOWN: ModelImporter.cpp:123: Searching for input: 415
UNKNOWN: ModelImporter.cpp:129: 415 [Resize] inputs: [388 -> (-1, 256, -1, -1)], [415 -> (4)],
While parsing node number 413 [Resize -> "416"]:
--- Begin node ---
input: "388"
input: "415"
output: "416"
op_type: "Resize"
attribute {
s: "nearest"
type: STRING
--- End node ---
ERROR: builtin_op_importers.cpp:2412 In function importResize:
[8] Assertion failed: scales.is_weights() && "Resize scales must be an initializer!"
The code snippet is:
// 1) Create a network definition, import the model
// 1.1.- Create the inference builder
IBuilder* builder = createInferBuilder(gLogger);
// Create the network definition
const auto explicitBatch = 1U << static_cast<uint32_t>(nvinfer1::NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
INetworkDefinition* network = builder->createNetworkV2(explicitBatch);
// 1.2.- Create onnx parser
nvonnxparser::IParser* parser = nvonnxparser::createParser(*network, gLogger);
// 1.3.- Parse the model
size_t verbosity{4};
parser->parseFromFile(DEPLOY_FILE, verbosity);
if (!parser->parse(DEPLOY_FILE, verbosity))
std::cout << "Failed to parse onnx file." << std::endl;
return nullptr;
I found similar issues in github like this. I do not know if I understood it well, so the nearest resize operation is not supported?
How could I solve this issue? Does upgrading to TensorRT 7.1 would help?
Thank you for your time
